Comskip 0.79 build 16 was made after extensive retesting leading to many small corrections and heuristics improvements thanks to the test files I received from users all over the world.
Most important improvement is the ability to correctly recognize a (very) short initial show segment followed by a commercial
Can be downloaded from http://mk.kaashoek.com/gbpvr/comskip79_16.zip
Comskip features a preview, edit and debug window.
A screenshot is available at http://mk.kaashoek.com/gbpvr/comskip.jpg
During analysis it will show, when activated, the progress of the processing.
When the analysis is finished it helps to review in detail the results alowing you to scan the timeline and visually check the processing results with the content of the mpeg file.
It also supports the editing of cutpoints allowing you to manually improve the results.
A guide describing the debugwindow can be found at http://mk.kaashoek.com/gbpvr/debugwindow.htm
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 17:57 -
New Build -- Please review!
By Deku Scrub in forum ComputerReplies: 17Last Post: 11th Nov 2009, 07:05 -
New PC Build
By faramith in forum ComputerReplies: 37Last Post: 19th Oct 2009, 16:26 -
Comskip debug window, missing video
By orev in forum EditingReplies: 6Last Post: 9th Dec 2007, 06:23 -
Looking for standalone version of Comskip with gui
By demonwarrior in forum Newbie / General discussionsReplies: 0Last Post: 11th Sep 2007, 03:37
