Hi everyone![]()
I have 2 AVI files. One file's audio volume is much louder than the other's. I plan to covert these AVI files to VOB files and author them onto one single DVD.
How can I fix the difference in audio levels?
I use DivXToDVD to convert the files.
you could normalize the audio or lower the volume with goldwave, open the avi, normalize ( read http://www.unterzuber.com/dubbing%20albums%20to%20cd.html scroll down to normalize ) or just lower the audio and then save as wav. multiplex/add the wav to the old avi with virtualdubmod, www.videohelp.com/faq#multiplex
Thanks, Baldrick
So this means I will first have a seperate .wav file (from my current .avi file), normalize it, then multiplex it back with my current .avi file.
I was hoping for a somewhat simpler way.
For example, is there a DVD authoring software that allows me to normalize the audio of the .vob files which I will be authoring onto a DVD? In other words, after adding all necessary files into the video_ts folder, before burning, is there a way to tell the authoring software to normalize the audio parts?
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 22:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 20:32 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
