I have 2 audio tracks. I can only select one track at a time. Is there a way to select both tracks ?
Thanks in advance.
I have the original audio on 1st track and music on 2nd track. Just want to mix track 1 & 2.
You have to do this in an audio editing application. You may have to convertt eh tracks to something you can edit (depending on what format they are), mix them down in your editing app, encode them back to a format you can use for DVD, then add them into your disc when authoring. DVD only allows for one audio track at a time to play.
Read my blog here.
OK ! So, I will have 3 tracks. Original, music, and original + music.
AFAIK, you can only select one audio track at a time on a DVD. I believe that for discs that have audio commentary, they mix the program audio (voice and music/FX) in the same track as the commentary dialog.
Like guns1inger said, you have to mix them into one audio file in an audio editing program like Adobe Audition. You might be able to achieve this in a free program like Audacity, but I'm not sure.
VOB2MPG multiple selective audio tracks
By hhhgamewmx7 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 11th Jul 2011, 04:49 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28 -
VOB to .ts with multiple audio tracks
By csaba1985 in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2007, 08:28 -
DVDShrink - Multiple audio tracks? What's what?
By kelemvor in forum DVD RippingReplies: 17Last Post: 16th Jul 2007, 12:07
