  1. Hi.
    Can anyone help.
    I've been sent some home dvds from relatives, and i would like to do some editing . and burn footage to new discs taking out all the parts
    i don't want.
    I have been using SHRINK, and been puting individual segements into seperate folders, then i use the TMPGEnc Dvd Author 1.6 to combine all.
    Trouble is, this is very time consuming doing it this way.
    Is there a Programme available that can do all this for me, or any other
    way that will be quicker.
    PS. Must be able to play on my dvd player.
    Thanks to all that reply.
    you can cut and join directly with tmpgenc dvd author.
    or maybe try videoredo, it can import dvd vobs and join and output as one mpg and then you author it.
