Running ProjectX 0.90.1.00/30.09.2005.
Demuxed a 15 minute mpg file into m2v and mp2. Problem is that the audio and video gradually goes out of sync. At the beginning it is right on but at the end the audio is .9 seconds too early.
Demuxed the same mpg file using TMPGEnc Plus. Audio/video sync perfect at the end.
Anyone know which setting in ProjectX to change to get it to retain audio/video sync?
I'm running the version compiled with Java which I believe is 0.90.1. The 0.90.3 version says "source code". Do I need a compiler to compile an exe file from the source code? And is Java an intrusive software if I install it?Originally Posted by Baldrick
I want to get ProjectX working instead of TMPGEnc because Encore hangs using using a TMPGEnc demuxed file while the same file demuxed using ProjectX works OK.
The weird symptoms are:
21 minute mpg file:
- Demuxed using TMPGEnc, Encore hangs when trying to create the timeline.
- Demuxed using ProjectX, Encore creates the timeline fine. Audio/video sync appears to be about right at the end but hard to tell if it is perfect since it is only music background with no lip sync. But audio is no where near 1 second off if it is off at all.
15 minute mpg file:
- Demuxed using TMPGEnc, Encore works fine and sync is perfect.
- Demuxed using ProjectX, Encore works fine but audio is about 1 sec too early at the end. Easy to tell since there is an action with a bang sound that is obviously 1 sec off.
Would you have any recommendations for a different mpg to m2v/mp2 demux tool? A different free one would be nice. I tried "demux" but the m2v file it created hangs in Encore using the 21 min file like TMPGEnc does.
Thanks for your help! -
Tried it but no difference. Audio still 1 sec early at end.Originally Posted by Soopafresh
Thanks,
MKS -
Just tried PVAStrumento. It does the exact same thing as ProjectX does in that audio at end is about 1 second too early. There must be a problem with the original mpg file which TMPGEnc fixes which allows the TMPGEnc demuxed streams to retain sync.Originally Posted by Baldrick
Thanks much for your help,
MKS
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
ProjectX Audio problems
By hhggzz in forum DVB / IPTVReplies: 0Last Post: 26th Jun 2010, 12:58 -
ProjectX is creating audio sync issues
By philled in forum Video ConversionReplies: 2Last Post: 20th Feb 2010, 18:02
