My question is this. I am making a data cd,the file(s) are 832mb,but the cd of course can only hold 700mb,my question is....... Is there any possible way that i can burn that file(s) onto the cd without having to delete or compress any of the files.
You could use a 90 minute CD, but trying to overburn a 700Mb CD to 832Mb is a little too much.
And I'm pretty sure not even Mode 2 / Form 2 can squeeze THAT much into the CD...
Just checked. Mode 2 can fit another 95 megs on there, for total of 795 MB. But 832 MB? No way. -
Thanks for the replys,could there be another way.I dont have the money to get a new dvd burner.Ive posted about the problem and we all came to that its broke.It reads and writes cd,reads dvd,but wont write dvds.Ok,back on post,is there another way.
Again
Thanks for the help. -
Hey kschang,thanks for the help,but one problem about that,how would i go about that.Do i use a program or what.
Again,thanks for the feedback. -
And technically it would no longer be of purview of this forum...
But really, search for WinSplit or even "split file" on Google should give you plenty of ideas.
DVDFlick burning question
By videodude1966 in forum Authoring (DVD)Replies: 6Last Post: 8th Nov 2009, 14:08 -
Question on burning CD
By tee jay in forum MacReplies: 2Last Post: 9th Oct 2008, 01:27 -
Burning question about Studio 10
By jimlong in forum Authoring (DVD)Replies: 1Last Post: 25th Sep 2008, 15:58 -
burning question...:-)
By Gunny in forum DVD RippingReplies: 12Last Post: 23rd Sep 2007, 18:54 -
ImgBurn burning question
By yogart in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 02:57
