I have a problem converting my mpg file to xvid using virtualdub mpeg2. I recorded a program on a dvd recorder. I took the VOB files and saved it to my hard drive. I used Mpeg Video Wizard to remove all the commercials and make it into an mpg file. I think the mpg file it is saved, the quality is "dvd long play" because when I play it on vlc, it says 21 minutes, but overall it's like 43 minutes. This is after it cut the commercials. Anyways, I used the guide https://www.videohelp.com/avi2divx.htm to guide me through my conversions, but when I click save to avi, it gives me a popup message "No audio decompressor could be found to decompress the source audio format. (source format tag:2000). Please help, and tell me where to click and what, because most of the terminologies that are used in this forum, i have no idea. Like Interlacing, demux, bit rate, stuff like that, I have absolutely no idea what these words mean, but I see it a lot in these guides. THANKS!!!
Results 1 to 9 of 9
I would convert to xvid with autogk or avi.net.
Or get the ac3 acm and you can decode ac3 in virtualdubmpeg2. -
I can't even get avi.net to work. downloaded it with the link on here, installed it, and then double clicked the icon avi.net and I get an error message saying: "The application failed to initialize properly (0xc0000135). Click OK to terminate the application." Any ideas? Thanks...
Do you have .net framework 2.0?
AutoGK is an alternative too, as Mr B says.
/Mats -
.net framework is what makes applications built with MS latest development package tick. Freely available from Microsoft.
No, AutoGK doesn't contain any spy/adware to my knowledge.
/Mats -
Find .Net Framework 2.0 here:
http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15...DisplayLang=en
Converting an MPG file to an ISO file.
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Dec 2009, 22:58 -
Best Method of IVTC to use In Converting HDTV .mpg to xvid
By onesikgypo in forum DVB / IPTVReplies: 7Last Post: 30th Sep 2009, 01:13 -
converting mpg file to MP4
By bdaul in forum ffmpegX general discussionReplies: 6Last Post: 16th Jul 2008, 17:54 -
Converting VOB file to MPG
By weenie02000 in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2008, 14:58 -
Converting a mpg file
By galehickey in forum Capturing and VCRReplies: 5Last Post: 28th May 2007, 10:03
