My 716AL seemed to be working fine, but all of a sudden, erasing and burning disks (both DVD+RWs and CD-RWs) have been giving me errors. I have the latest firmware from Plextor's site, so i dunno what gives.
I was able to save the error log on this last burn attempt i did... anyone figure it out?
Code:5C80001080000000002666685258 Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'F:\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM NT-SPTI used Nero Version: 7.0.0.0 Recorder: <PLEXTOR DVDR PX-716AL> Version: 1.01 - HA 1 TA 0 - 7.0.0.0 Adapter driver: <IDE> HA 1 Drive buffer : 8192kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <PLEXTOR DVDR PX-716AL >Version: 1.01 - HA 1 TA 0 - 7.0.0.0 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : NVIDIA STRIPE 138.49G nvraid Port 0 ID 1 DMA: Off CdRomPeripheral : PLEXTOR DVDR PX-716AL nvatabus Port 1 ID 0 DMA: Off CdRomPeripheral : PLEXTOR CD-R PX-W1610A nvatabus Port 1 ID 1 DMA: Off DiskPeripheral : IC35L020AVER07-0 nvatabus Port 1 ID 2 DMA: Off DiskPeripheral : WDC WD740GD-50FLC0 nvatabus Port 2 ID 0 DMA: Off DiskPeripheral : Maxtor 6B200S0 nvatabus Port 3 ID 0 DMA: Off DiskPeripheral : WDC WD740GD-50FLC0 nvatabus Port 3 ID 2 DMA: Off === CDRom-Device-Map === PLEXTOR DVDR PX-716AL D: CDRom0 PLEXTOR CD-R PX-W1610A E: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 2047MB (2096608kB) Free physical memory: 1022MB (1047276kB) Memory in use : 50 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 14.1.2006 CD Image 10:37:52 PM #1 Text 0 File Burncd.cpp, Line 3007 PLEXTOR DVDR PX-716AL BURN-Proof activated 10:37:52 PM #2 Text 0 File ThreadedTransfer.cpp, Line 525 ReadBuffer-Pipe got 81920KB of Memory 10:37:52 PM #3 Text 0 File Reader.cpp, Line 124 Reader running 10:37:52 PM #4 Text 0 File Writer.cpp, Line 113 Writer D: PLEXTOR DVDR PX-716AL running 10:37:52 PM #5 Text 0 File Burncd.cpp, Line 3301 Turn on Track-At-Once, using CD-R/RW media 10:37:52 PM #6 Text 0 File DlgWaitCD.cpp, Line 277 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 347873 ( 77:20.23) 10:37:52 PM #7 Text 0 File DlgWaitCD.cpp, Line 289 Write in overburning mode: NO (enabled: CD) 10:37:52 PM #8 Text 0 File DlgWaitCD.cpp, Line 2568 Recorder: PLEXTOR DVDR PX-716AL 10:37:52 PM #9 Text 0 File DlgWaitCD.cpp, Line 456 >>> Protocol of DlgWaitCD activities: <<< ========================================= 10:37:52 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 846 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, Joliet) 2 indices, index0 (150) not provided original disc pos #0 + 347874 (347874) = #347874/77:18.24 relocatable, disc pos for caching/writing not required/not required, patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 347872 blocks [D: PLEXTOR DVDR PX-716AL] -------------------------------------------------------------- 10:37:52 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1058 Prepare recorder [D: PLEXTOR DVDR PX-716AL] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 712753152, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0x00 -150 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 347874 | lead-out | 1 | 0x41 | 0x00 10:37:52 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1126 Removed 2 run-out blocks from end of track 1. Length: 347874 -> 347872. 10:37:52 PM #13 Text 0 File SCSIPassThrough.cpp, Line 34 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 10:37:52 PM #14 Phase 24 File dlgbrnst.cpp, Line 1724 Caching of files started 10:37:52 PM #15 Text 0 File Burncd.cpp, Line 4129 Cache writing successful. 10:37:52 PM #16 Phase 25 File dlgbrnst.cpp, Line 1724 Caching of files completed 10:37:52 PM #17 Phase 36 File dlgbrnst.cpp, Line 1724 Burn process started at 4x (600 KB/s) 10:37:52 PM #18 SPTI -1189 File SCSIPassThrough.cpp, Line 306 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1189) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x02 CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 02 Buffer x037ada00: Len x4000 10:37:52 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2669 Verifying disc position of item 0 (relocatable, no disc pos, patch infos, orig at #0): write at #0 10:37:52 PM #20 Text 0 File MMC.cpp, Line 21541 Set BUFE: BURN-Proof -> ON 10:37:55 PM #21 Text 0 File Cdrdrv.cpp, Line 1195 22:37:55.578 - D: PLEXTOR DVDR PX-716AL : Queue again later 10:56:56 PM #22 SPTI -1135 File SCSIPassThrough.cpp, Line 306 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x07 CDB Data: 0x2A 00 00 05 39 20 00 00 20 00 00 00 Sense Area: 0xF0 00 03 00 05 39 B6 0A 00 00 00 00 0C 07 Buffer x044f0000: Len x10000 0x15 CE F5 35 95 12 6F 4E B1 32 CE E5 71 46 5A 58 0x96 D4 C6 16 65 46 D6 BA 93 95 EF 05 3E E5 16 4B 0x2B 09 AA 22 CF 59 96 62 8E A5 38 1B 72 73 09 BA 10:56:56 PM #23 CDR -1135 File Writer.cpp, Line 302 Write error D: PLEXTOR DVDR PX-716AL 10:56:56 PM #24 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 10:57:03 PM #25 CDR -201 File WriterStatus.cpp, Line 200 Invalid write state D: PLEXTOR DVDR PX-716AL 10:57:03 PM #26 TRANSFER -18 File WriterStatus.cpp, Line 200 Could not perform EndTrack 10:57:03 PM #27 Text 0 File MMC.cpp, Line 16273 <PLEXTOR DVDR PX-716AL > start Close Session 10:58:42 PM #28 SPTI -1176 File SCSIPassThrough.cpp, Line 306 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1176) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x72 Sense Qual: 0x02 CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00 Sense Area: 0xF0 00 03 00 05 3B 93 0A 00 00 00 00 72 02 10:58:42 PM #29 CDR -1176 File WriterStatus.cpp, Line 249 Session fixation error D: PLEXTOR DVDR PX-716AL 10:58:42 PM #30 TRANSFER -19 File WriterStatus.cpp, Line 249 Could not perform Fixation 10:58:42 PM #31 Text 0 File WriterStatus.cpp, Line 258 falling back to disc fixation 10:58:42 PM #32 Text 0 File MMC.cpp, Line 16273 <PLEXTOR DVDR PX-716AL > start Close Session 10:58:42 PM #33 SPTI -1026 File SCSIPassThrough.cpp, Line 306 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1026) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x2C Sense Qual: 0x04 CDB Data: 0x5B 01 02 00 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 2C 04 10:58:42 PM #34 CDR -1026 File WriterStatus.cpp, Line 249 Current program area empty D: PLEXTOR DVDR PX-716AL 10:58:42 PM #35 TRANSFER -19 File WriterStatus.cpp, Line 249 Could not perform Fixation 10:58:42 PM #36 Phase 38 File dlgbrnst.cpp, Line 1724 Burn process failed at 4x (600 KB/s) Existing drivers: File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 12/5/2005 12:12:26 AM (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 1 of 1
Plextor PX-B310U
By ruktuim in forum DVD & Blu-ray WritersReplies: 1Last Post: 29th Apr 2009, 13:46 -
Plextor PX-AV200U or ???
By wtsinnc in forum Capturing and VCRReplies: 4Last Post: 11th Nov 2008, 13:46 -
Plextor PX 716 problems
By cajmere in forum DVD & Blu-ray WritersReplies: 11Last Post: 31st Dec 2007, 06:37 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 18:27 -
Plextor PX-760A
By SCDVD in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Aug 2007, 01:24
