Is there ANY way that good/best quality vhs recordings can be made HD for future dvd generations? Using up converters ar anything you guys know of-Thank You.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
it would probably look as good as the original.. and i'm sure, in time, it will be possible.
The question is "Why?" It's like going to the grocery store in a Bentley.
First all HDTV sets can upscale analog composite inputs internally.
VHS has less than 352x480/576 actual resolution. On a HDTV display, a 720x480/576 capture might look less pixelated than 352. Either 352 or 720 will be upscaled by the HDTV to its native display resolution.
There is no advantage from upscaling the capture file beyond 720x480/576. It will only make the file size larger.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
