Verbatim DVD, is this MCC code?
http://www.cdrdvdrmedia.com/verbatim-8x-dvd-r-media-95087.html
I 'm not sure. Because price is too low.
According to their site, that media is: https://www.videohelp.com/dvdmedia.php?selectmedia=1805#comments
If so, it sounds OK. The listed media code is MCC 02RG20. If you input that in 'DVD Media' to the left >>>> as a DVD Media code, then scroll down to Verbatim, you will see the entry.
Of course it still needs to be compatible with your burner and standalone player.
Long-Term Storage - Verbatim DVD-R 16x (MCC) still BEST/IDEAL ?
By quantass in forum MediaReplies: 7Last Post: 29th Jan 2010, 01:14 -
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 02:15 -
Pioneer DV-400V won't read Verbatim MCC-004
By unknownsoldierX in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Sep 2008, 15:55 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 04:37 -
Different printable MCC 03RG20 brands?
By burgul in forum MediaReplies: 5Last Post: 19th Dec 2007, 09:11
