Hey guys! I've looked around the forum, and others forums as well, including the official forum for AC3Filter, and I haven't been able to get any straight answers anywhere, so I thought, why not ask the experts
The problem I'm having is most probably a hardware/software issue, so I wasn't sure where to place this thread, so mods, please feel free to move it at your discression.
Here's the issue: For the longest time I've been trying to configure my audio so that the sound in AC3 encoded files would provide better sound quality when it came to voices in movies, etc. I've tried changing hardware, software, codecs, players, etc, but I seem to not be able to get any better quality... this is my current setup, and please ask if you need to know more:
Soundblaster Live! 5.1
Zalman 5.1 ZM-RS6F Headphones
AC3Filter 1.01a RC5
If anyone would be so kind as to give me some assistance with this problem, or even point me in the right direction (other boards, sites, etc), it would be GREATLY appreciated! Thanks in advance guys![]()
Results 1 to 9 of 9
Well, first off, thanks for replying so quickly!
I've tried using VLC, WinDVD, PowerDVD, MicroDVD, and Zoom Player, with relatively similar results - the voices stay the same, barely audible
By better sound quality with voices, I pretty much mean so that I can hear them without having to blast up the sound and make myself go deaf with the rest of the sounds in the movie clip.
I've already tried messing with the options in AC3Filter configuration panel, boosting the centre speaker, the voice gain, the master gain, etc., but nothing has given me the effect where all other sounds stay the same but the voice becomes more audible, which is exactly what I'm trying to do :/ -
You'll probably get quicker/better answers to this in the audio forum. Ask a mod to move it for ya.
FB-DIMM are the real cause of global warming -
Thanx for the advice rallynavvie, and if there's a mod reading this thread, and you think I'd get a better response in the audio forum, please move it over at your convenience
Update: I just messaged a mod to move it over
Well that mod must be in the videohelp bathroom so I'll move it for you.
"For the longest time I've been trying to configure my audio so that the sound in AC3 encoded files would provide better sound quality when it came to voices in movies, etc. I've tried changing hardware, software, codecs, players, etc, but I seem to not be able to get any better quality..."
If a DVD uses the theater tracks for audio, normal dialog can vary from low to nearly inaudible, the reason being, you don't have the same equipment or listening environment.
The easiest way to fix it for listening/viewing is to use something like Power DVD and set the audio environment or whatever to compress the audio volume into a smaller dynamic range, sort of averaging the loudness. Depending on your version, plugins etc., you'll get several choices. -
Thanx for the help mikiem!
Any other suggestions, especially ones that may help me improve AC3 sound quality in general (over all players) would still be much appreciated
DTS to AC3 audio conversion (using MP4Tools on a Mac) issue/problem
By SimonSimon in forum AudioReplies: 1Last Post: 1st Sep 2011, 04:41 -
[solved]What is the proper way to fix an ac3 synch issue in a h264 mkv file
By yoda313 in forum AudioReplies: 0Last Post: 16th Apr 2011, 09:46 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 22:53 -
Help in CAVLC decoding
By krao in forum ProgrammingReplies: 0Last Post: 15th Jul 2010, 16:55 -
AVS Video Converter and True-HD Audio (AC3+) issue
By lionelblair in forum Blu-ray RippingReplies: 3Last Post: 18th Sep 2009, 06:36
