Hello, I'm trying to play a movie from the VIDEO_TS.IFO file, inside the VIDEO_TS folder, but it doesn't work at all -.-
It just says "Stop" after like 1 second.
If I play each VOB file individually, everything goes ok, they're split in 17 mins or so each, but playing the VOB files individually means no subtitles (as far as I know) and the movie isn't in a language I can understand.. -.-
so I really need the subs.
The files I have in the folder are:
VTS_02_3.VOB
VTS_02_2.VOB
VTS_02_1.VOB
VTS_02_0.IFO
VIDEO_TS.IFO
VTS_02_0.BUP
VIDEO_TS.BUP
I downloaded a tool called IfoEdit, since I read that the current IFO files could be damaged or something.
I followed some guides and none worked, still I can't play the movie, it automatically stops after 1 seconds or so.
Do you have any idea of what could be going on and how can I fix it?
delete all the .ifo and .bup files ..... rename all the vobs to VTS_01_x (x will be the same as it is in the vobs you have .. ie VTS_02_1.VOB will become VTS_01_1.VOB and so on) now open ifoedit and select create new ifo's and load up the first vob (VTS_01_1.vob) and tick to save ifos in 'same as source' ... close ifoedit then reopen it and click open ... select and open the new VIDEO_TS.IFO then click get vts sectors ... click ok (several times) .. close ifoedit ... play the dvd files ... they should now work correctly
Holy ****, I think I love you.
It works now, almost perfect though.
I can't see the subtitles properly, they are all green.
Any ideas? -
Nevermind it, I fixed it.
For anyone who might have this problem, this is how I fixed it.
In IfoEdit, open VTS_01_0.IFO from another DVD with working subtitles (like the original IFO from the DVD), to get the correct color table, so then just select VTS_PGCITI from the treeview, then VTS_PGC_1, and select 'Copy colors from this PGC'
Then load the copy IFO, select the same PGC and choose 'Paste colors into this PGC'
Works perfect now ^^
recreating vob ifo files
By krohm in forum Authoring (DVD)Replies: 25Last Post: 15th Jun 2009, 06:27 -
What should i do with vob/ifo files?
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2008, 02:26 -
Create IFO from VOB w/o IFOEDIT?
By theschles in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 19:19 -
VOB IFO and VOB, clueless need expert help :)
By Skunk141 in forum Authoring (DVD)Replies: 5Last Post: 13th Dec 2007, 16:03 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38
