    Jan 2006
    Sorry but I have absolutely no idea how to achieve this.
    I have a Humax PVR-9200T and I have transferred a recorded programme to my PC and now I want to record it onto DVD.
    I am not totally sure what format the file is currently in, but I would hassard a guess at .mpg.
    I have no idea where to go from here and if possible I want to use free tools or atleast tools with a trial period.
    Hope this isn't too complex.
    Thank you for your time.
    we need more information about the source video. use latest gspot beta or videoinspector to identify the mpg source, it will tell you video size,framerate, audio ccodec,video codec etc.
    if it is dvd compliant you can author and burn it directly using for example tmpgenc dvd author, you can test add the mpgs and it will tell you if it is dvd compliant.
    if isn't dvd compliant you can use an all-in-one tool and convert it to dvd like for example the old free divxtodvd.
    Jan 2006
    running videoinspector does not work. Gspot shows: [/img]
    latest gspot beta, 2.52. not 2.21.
