  1. Anyone know a way of 'recording' or saving the flash animations from the web, so I can burn Video-DVD's of them to show to 'normal' non net attic friends of mine....
    Plus also theres a hidden messages in some I know of, could freeze frame and read them on a DVD disc.
    Any ideas, help much apericated.
    DVD region settings are a joke, I can't believe how stupid people are falling for it
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    You can use something like Camtasia, or simply get the url of the file, download it, then run it locally. If you right click on it, you can pause it(deselect play). It is not really necessary to convert them.
    Also, there are tons of guides on this.
  3. http://www.fat-pie.com/spoilsminus2.htm
    try pressing pause and reading the messages in that. I want to do it to show some of my friends without needing a computer mainly
  4. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Here is the direct link:
    http://www.fat-pie.com/spoilsminus2.swf
    Open in your browser, eg Firefox, Click on file menu, Save Page as; the file will now be saved in flash format (swf).
    PS. all I did was change the htm to swf and the saved file works.
    Enjoy
  5. Greetings Supreme2k's Avatar
    Feb 2003
    Is this the secret message?
    BTW, that was pretty fucked up.
