so is it a moot point that one must use additional equipment between a VCR and dvd recorder? I've had varyng luck with Panny es20 and Toshiba dr4, and very poor luck with JVC drm100 and a Liteon. None have been keepers. I use two Panny vcrs (the newer models from 2002-3) and gold-plated (whatever) RCA cables. The dvd recorders have magnified any signal problems on a vhs (even when the problem was barely visible); the Toshiba is supposed to have a TBC in it but it still wigs out with more noticeable problems. The Panny did better on noticeable problems but flickered (in the same spots) when there was no noticeable problem on a vhs. The JVC changed the color saturation back and forth, and also flickered (a large white horizontal block) during barely visible vhs problems.
There are some good tips for copying VHS to DVD at this page: http://www.signvideo.com/conv-v-to-d.htm
Software/equipment needed for two way web-conferencing
By p_s_92 in forum Newbie / General discussionsReplies: 5Last Post: 27th Jul 2010, 21:36 -
Which VCR and DVD Recorders?
By Canes in forum DVD & Blu-ray RecordersReplies: 26Last Post: 11th May 2010, 20:48 -
What equipment is needed for this kind of setup?
By Castle Party Rentals in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2009, 16:23 -
Question about DVD Recorders - Can I plug a VCR to it?
By donovan99 in forum Newbie / General discussionsReplies: 9Last Post: 23rd Aug 2008, 11:28 -
Equipment advice needed for VHS to PC capture.
By kajinofe in forum Capturing and VCRReplies: 23Last Post: 19th Nov 2007, 17:45
