Results 1 to 9 of 9
  1. I been experimenting with Nero, the sound on my VCD come out all choppy and behind, is there a better convertor and what audio settings should i have on? thanks Galvin
  2. Use TMPGEnc to convert AVI to MPEG. It's the best and
    it's free!
    You can get it at http://www.tmpgenc.com
    vcddude
  3. I have that but the sound is kinda distorted, I thikn I need to change my audio settings, should I put it on a lower biitrate or sumthing? I played the VCD through Windows, it was fine but when I played on PSX the sound was messed up.
  4. The 224 kb/s should be the norm for a VCD .
    I always extract the DIVX AVI audio using this method
    http://www.vcdhelp.com/virtualdubaudio.htm
    and save as a WAV then reload the original movie along with the saved WAV and output to MPEG 1 VCD.
  5. Should I put the audio settings down................ they are currently on
    Sampling Frequency - 4100
    Channel Mode - Stereo
    Bitrate - 192
    should I make them smaller to stop the glitches?
  6. The most common template i use is the NTSC VCD Film ..
    it uses:
    44,100
    and
    224
    and I have no problems.
    Many people like Nero but personally I always get frozen up at the end of a session so try VCDEASY.
    I find its quite easy and has given me many succesful burns.
    http://www.vcdhelp.com/vcdeasy.htm
  7. does it usually take 6 hours to decode?
  8. Yes...unfortunately about 4 to 6 hours on average
  9. haha ok thanks guys, i suppose its worth it
