    Dec 2005
    Australia
    hi i have a files that im having troubles with audio
    there both the same format audio when i feed them through gspot
    audio codec name: 0x0055(MP3) ID'd as MPEG-1 Layer 3
    audio codec bitrate: 128 kb/s (64/ch, stereo) VBR LAME3.92
    now im having troubles with vbr as cbr i find it easy to either use the audio extraction guide and making a wav file or using avi decompressor to create a pcm file but for vbr it doesnt seem to work and when i try encoding it in tmpgenc and go to source range after loading the audio it still gives me a flatline without any sound stream
    is there another program that works with vbr lame 3.92 layer 3 or would i need a special codec?
    i have ace megacodecs pack dashboard and everything is enabled
  2. What doesn't work with vbr?
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Codec packs are evil! A safe way to wreak havoc with your media capabilities.
    /Mats
    Dec 2005
    Australia
    yeah but the thing is ive converted over 100 divx files over the past month and im only having troubles with the 2 vbr with lame 3.92
    is there a special codec for this?
    tmpgenc gives me a flat line in sound range so if i convert and burn i wont hear the audio right?
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    VBR audio in avi is always a PITA for almost any encoder.
    /Mats
    Aug 2005
    Right here
    I assume, from what you wrote on your first post, you already tried VirtualDub/Mod with no success.
    I usually resolve those hard issues with VBR audios using either Goldwave either Graphedit.
    Good luck.
