Hi to all. I'm trying to convert decoded pictures from MPEG files (using libmpeg2) into RGB colospace. I need it because my video output module uses only RGB colorspace.
Now, I've investigated enought to understand that the most people doesn't know about this conversion.
Most rielable sources I've found are wikipedia and fourcc.org. On wiki http://en.wikipedia.org/wiki/YUV, while on fourcc.org http://www.fourcc.org/fccyvrgb.php.
I've used the foucc.org formulas, but my resulting RGB values are out of range of 0-255!!! I've tried to cut-off negative values to 0 and >255 values to 255, but this doesn't works. I've tried also to scale full range values to 0-255, but this also doesn't works!!!
I'm beginning to think that formulas are wrong.
It take the most accurate the matrix proposed by wikipedia. So, calcultaing the inverse matrix for converting YUV to RGB, I should obtain the conversion matrix from YUV to RGB, isn't it?
Well, I've found this page to calculate the inverse matrix of the conversion matrix proposed by wikipedia.og: http://lnx.arrigoamadori.com/CalcoloNumerico/Matrice3x3InC/Matrice3x3InC.htm
The result was a little different from all sources I've found. But applying this formulas doesn't works so much...
Anyone can clarify me about?
P.S.: at the moment I'm not worried about performance. When the conversion will works, I will use a fixed point lookup table to achieve the result using only additions... but I'm going to be crazy about this quest...
Can you post some code snips as to how you are using this libmpeg2 to
recieve the image data ??
From reading this, it seems you are doing the following with this lib:
** opening MPEG-2 source files (ie, m2v or mpg)
** .. process to obtain image ..
** receive YUV data and saving to a file ? or inside a matrix array ?
Maybe if we see how your source image is obtained, we can go from there
Coefficients -- 0.299; 0.587; 0.114; ...
Some people refer to it as 'coefficients'. But its all basically the same
thing.
Here is code snip from my YUV tool. For now, inside the current code
snip, I just use generic terms.. (could change at any time of development)
My code is very spagetti like. But have a look at what I mean below,
regarding coefficients.
In line 0, this is the main one that works for most of my methods of
dealing with image conversion. But, I do my *own* RGB<->YUV conversions
using the same formula pairs, so I don't have any issues as you seem to
be having. But, I have the other coefficients for other conversions as
well, depending on how I want to 'convert' - RGB->YUV first. The others'
are lines 1 and 2 for the varialbe valCoef instance:
-vhelp 3748Code:case valCoef of 0: begin ituR:= 0.299; ituG:=0.587; ituB:=0.114; end; 1: begin ituR:= 0.257; ituG:=0.504; ituB:=0.098; end; 2: begin ituR:= 0.215; ituG:=0.7154; ituB:=0.0721; end; end; -
I played a little with the code, and I found the right conversion formulas:
#define GETR(y,u,v) ((1.164 * (y - 16)) + (1.596 * ((v) - 128)))
#define GETG(y,u,v) ((1.164 * (y - 16)) - (0.813 * ((v) - 128)) - (0.391 * ((u) - 128)))
#define GETB(y,u,v) ((1.164 * (y - 16)) + (2.018 * ((u) - 128)))
Images seems to be in the right color using these formulas.
These formulas won't be used, because floating point operations are too expansive, but they works well (that's because I should convert YV12 images for displaying on video; I've already an output module wich display automatically YV12 images using speicfic hardware present on video cards, but now I'm tring to do it manually).
y, u, v values ranges are [0,255] (at least I think... I've not yet investigated on returned YUV images by libmpeg2, maybe YUV values have restricted ranges).
Now, what I'm planning is to precalculate floating values, store results in a fixed point notation. These values are indexed in a structure like that:
So converting a YV12 pixel should be sufficient adding 2/3 coefficient stored in the tables. The add operation is done on integer values, so it should be faster than using directly floating point operations.Code:typedef struct _img_csc_yuv2rgb_table_s { gva_fixed_t rgbY[256]; /**< Red, Green, Blue luminance component. */ gva_fixed_t rU[256]; /**< Red U chrominance value. */ gva_fixed_t rV[256]; /**< Red V chrominance value. */ gva_fixed_t gU[256]; /**< Green U chrominance value. */ gva_fixed_t gV[256]; /**< Green V chrominance value. */ gva_fixed_t bU[256]; /**< Blue U chrominance value. */ gva_fixed_t bV[256]; /**< Blue V chrominance value. */ } yuv2rgb_table_t; /* Table initialization code */ for (y = 0; y < 256; y++) for (u = 0; u < 256; u++) for (v = 0; v < 256; v++) { /* initialize coefficient table using formula definition */ }
After 2h...
This is done. The fixed point operation is good and it works well. But there is a problem: R, G, B components will go out of range [0, 255], so I have to clamp them...
Premiere RGB exports produce bad frames - is YV12 a good alternative?
By spicediver10191 in forum Video ConversionReplies: 5Last Post: 21st Feb 2011, 18:02 -
YV12 to RGB color problem
By wydesenej in forum Video ConversionReplies: 2Last Post: 30th Oct 2009, 08:42 -
Help with captured AVI: Vdub / HCenc / RGB / YUY2 / YV12
By Rinsin in forum Video ConversionReplies: 2Last Post: 13th May 2009, 19:57 -
DVD to DVD: YV12 to RGB to YV12, color problem ???
By cd090580 in forum RestorationReplies: 9Last Post: 24th Oct 2008, 11:16 -
Optimized Conversion between YUV and RGB
By Dave1024 in forum ProgrammingReplies: 14Last Post: 27th May 2008, 02:40
