Does anyone know the difference between constant quality and constant bitrate? To me it sounds like if I use CQ(50%) at 2000kbps or CBR at 1000kbps they should be the same. Does anyone have an explanation for these two?
I've also noticed when I load the SVCD template that the default for bitrate is CQ. Does this have anything to do with differences in MPEG-1 and MPEG-2? If someone does know the differences between the two, what are the advantages of one over the other? Any advice or comments would be appreciated.![]()
Results 1 to 1 of 1
picture size difference after transcoding (TMPGenc 2.5)
By jakewoodblues in forum Video ConversionReplies: 12Last Post: 27th Apr 2010, 20:57 -
TMPGEnc Products - Notice Difference
By niteghost in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2009, 20:15 -
what is the difference between VBR and CBR of a mp3 file?
By sumeshkri in forum AudioReplies: 3Last Post: 19th Sep 2008, 07:31 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 20:06 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
