  1. Hi,
    I am trying to create a home movie, with Adobe Premier elements.
    When I test it on my PC, the picture is fine, when its convereted to DVD, on the TV quite a bit is missing from the edges. I relise this is over scan.
    Can I?
    Reduce the amount of overscan
    change the part of the avi to be scanned (move it to the left?)
    Many thanks in advance
    Q
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    You should be allowing for overscan when you shoot your video.
    After the fact, you would need to shrink the image and apply a border.
    See the bottom of this link
    http://atec.utdallas.edu/midori/Handouts/camera.htm
    http://www.kiva.org/about
