In a post above, willrob wrote: "If you upgrade OSX to 10.4.4, IDVD will no longer require the "French" patch to write DL disks."
I am running OS 10.4.4 (Tiger) and I cannot get iDVD 5 to burn dual layer to my Pioneer 110D. The option is just not there. What am I missing? I ran Patchburn so that my iApps would recognize the drive (which they do), but iDVD doesn't give me the DL option.
The firmware on my Pioneer 110D is 1.37. I have not "flashed" it with anything (unless Patchburn counts). I do NOT care about getting the DVD-RAM capability, but I DO want to burn dual-layer from iDVD. Any suggestions? Do I need to run that "French patch"? Does anyone have experience using it? And if I run it, do I need to uninstall Patchburn? (If so, how will all the other apps like iTunes recognize the Pioneer 110D?)
I appreciate any help you can give.
I'm using a G4 Digital Audio 1.33 Ghz/1 GB RAM, iDVD 5. I also have Toast 6.0.9 but would prefer to use iDVD for dual-layer burning.
Results 31 to 33 of 33
Ok I upgraded nto 10.3 and ran patchburn. it now says it is supported. I can't flash the firmware it says it can't find the dvd rw. anyway if it is not rocket science then why not make it simpler to do heheh
Caopus ADVC 110 issue
By codeman in forum Capturing and VCRReplies: 2Last Post: 11th Dec 2011, 15:56 -
Macrovision and Canopus ADVC 110
By nikgelfi in forum Capturing and VCRReplies: 2Last Post: 13th Apr 2011, 17:09 -
Canopus ADVC 110 Possible problem?
By Drexter in forum Capturing and VCRReplies: 4Last Post: 20th Feb 2010, 22:10 -
Kworld ATSC 110 Problems
By Robert Simandl in forum DVB / IPTVReplies: 0Last Post: 2nd Sep 2007, 11:37 -
ADVC-110 and Vista
By shkinnybob in forum Capturing and VCRReplies: 3Last Post: 3rd Aug 2007, 17:23
