Hey,
Ive got a video which i'd like converted to mpeg video. Its a .avi (uyvy).
Is there anyway (without buying an expensive plug in) to convert this from my timeline into mpeg?
Ive tried exporting it directly to lossless avi but the quality is not as good.
Any ideas?
Thanks.
Which version of Premiere do you have? I know that in Premiere Pro 1.5, you can create MPEG-1 or MPEG-2 easily as long as you have already your AVI file on the timeline. I am not sitting in front of my own home computer now, but I believe that you go to File, then Export, and then Adobe Media Encoder. If it's not under Export, it is definitely under the File menu somewhere, and its name may not be exactly as I mentioned, but it is along those lines. If I recall correctly there are presets for MPEG-1 and for MPEG-2 and probably Quicktime, Windows Media, and RealMedia. Under MPEG-1 and MPEG-2 there are further presets for DVD, SVCD, VCD, etc.
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0 -
Any full Premiere version from v6.5 on have the internal (Mainconcept based) MPeg1/2 encoder.
http://www.kiva.org/about -
delete second post
Is there a way to capture directly to MPEG-2 on a Mac?
By pf4711 in forum MacReplies: 10Last Post: 24th Feb 2012, 18:15 -
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 07:23 -
Converting videos for playback directly on Xbox 360...
By kevinmd88 in forum Video ConversionReplies: 3Last Post: 17th Aug 2011, 23:09 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Question - Capturing to MPEG directly with VHS cropping
By joejoe in forum Capturing and VCRReplies: 2Last Post: 24th May 2009, 22:45
