Could any of the membership who use movies 2.0 please enlighten me
on the correct settings when recording and copying to dvd disks.
i.e. the correct settings to record in Pal and also Ntsc and which should be
used either custom-vhs quality or none of these two, and finally what is
the correct bit or bite setting.
I found a few different references to "movies 2.0", but I'm not sure which software you are actually using. I've never heard of it.
Bit setting is used on +R media and is used to make the media appear as a commercial disk. It helps compatibility with some players.Google is your Friend -
Not too many good reviews on this software.Originally Posted by vergil7
Check here: https://www.videohelp.com/tools?tool=Magix_Movies_on_CD_DVD#usercomments
I've found most products by Magix as cheap programs that don't do a whole heck of a lot. You can usually find Magix products pretty cheap at places like Fry's Electronics (usually around $10.)
I've never used this product, so I can't comment directly on it.
Correct Project and Sequence Settings for footage from Panasonic TM300?
By Bloodredthorn in forum EditingReplies: 0Last Post: 20th Jan 2012, 13:34 -
Correct Settings for 16:9 Anamorphic DVD?
By helplessandlost in forum Authoring (DVD)Replies: 0Last Post: 17th Jan 2010, 12:47 -
Correct Settings in Image Burn for HD-DVD?
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 17th Jan 2009, 18:01 -
Settings Correct? Taking a Long Time/.avi to DVD
By 5Buffalo in forum ffmpegX general discussionReplies: 3Last Post: 24th Dec 2008, 15:29 -
Correct settings for encoding video for the 'new' YouTube format?
By Captain Satellite in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2008, 18:45
