As the MPEG4 limit for iPod encoding is 480x480 (230,400 pixels) and one may alter the ratio as long as the pixel limit is respected (640x360 is also okay), I wondered if the same "pixel limit" held true for H264 (320x240 = 76,800 pixels total). In other words: Would an H264 width larger than 320 pixels be accepted by the iPod as long as the width x height was no more than 76,800 pixels?
I'm really pleased to report that this works fine. I used ffmpegX (9uR2) to convert an AVI over to "iPod H264" last night. As the title was "wide-screen", I played with my calculator a bit until I came up with 416x176 as matching the original ratio. 416x176=73,216 pixels - under the 76,800 pixel limit.
In order to maximize the quality (and still keep the file size reasonable), I used 450kbps, Qmin:3, Qmax:30, Keyframe:20, Audio:96kb, ME function: Multi-hexagon. I use "Decode with QuickTime" all the time simply because it works all the time. Other checkboxes are left as is.
The 1:24:00 file ended up at 332MB and, at H264's quality, is a substantial improvement over an MPEG4 encoding at the same pixel size or even a considerably larger pixel size. It's also considerably better than if I had used 320x144 (the closest acceptable width to the movie's original ratio). Do the math: 320x144=46,080 or 63% of the 73,216 pixels I had in my final file.
By the way, the method I use to drop my video files into my iPod is just that: Drop the file directly into the iPod within the iTunes interface (not the mounted iPod in the Finder). The file never exists in my iTunes Library. Some folks are reporting problems going from the iTunes Library to the iPod with the 6.0.2 iTunes and the latest firmware update. Using this method I have no problems.
iPod classic limit for AAC NOT 160 kbps! Supports 320 kbps!
By FallenAngelII in forum AudioReplies: 1Last Post: 29th Dec 2007, 12:14 -
AVI conversion to H264 for iPod not quite working
By rumplestiltskin in forum MacReplies: 11Last Post: 1st Dec 2007, 00:48 -
Sound problems with h264 (iPod conversion)
By hackwojr in forum ffmpegX general discussionReplies: 17Last Post: 15th Jul 2007, 20:45 -
Flash FLV Internet Video Larger than 320 x 240
By foochuck in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2007, 11:49 -
larger file size from .avi to h264
By sai351 in forum Video ConversionReplies: 3Last Post: 4th Jun 2007, 13:20
