I have this burner and when i make a backup of a movie it has been having problems playing in my dvd player and pc.
This is what i do to backup my movies:
I first tryed Anydvd and Clonedvd and that worked for my first backup no problem but i then started to have problems with those two programs so i looked over this site and found that alot of people were talking about dvdshrink and dvd decrypter so i tryed that. i then bring up dvd shrink and drag the file i want to burn over to the left and go to backup. then when the box comes up for that i go to select backup target and go to create ISO image file and burn with dvd decrypter and it goes through the encoding process then the analyis process then it burns the movie. it finishes the movie and the little sound comes up telling me its done. i have tryed this many different times writing it at the max speed all the way down to 1X but....
I get this problem:
i go to put the movie in my pc to play it and see if it worked and it will be fine for the first 30 min or so then the movie starts to blur together and freezes. after about 20 seconds of it being frozen the screan goes blank and it says error unable to read disk. i then try to play it in my dvd player but i still get the same problems around the same part of the movie.
I had just got this burner last month and have went through many dvds. that parts ok cuz i know its going to take some time to get it correct but i was wondering what i was doing wrong and what can be done.
The blank dvds i have been using are Maxell dvd-r and i have tryed Maxell dvd+r. are these dvds garbage? and is it possible that i just got a bad spindle of dvds cuz i have had that problem with cd?
When you are first learning to do a new process, I would recommend burning onto DVD-RW discs. That way, if it doesn't work, you can reuse the disc.
My first guess would be bad media, but you state that you have tried 2 types (even though they are the same brand). You could try a different brand just to rule out the media. If it still doesn't work, then you are having a different issue.
The next step would be to burn a data disc. Just fill a DVD with random files (pictures, videos, music, whatever). Then test the disc to see if all of the files are readable. If it works, then you are having an issue with your dvd copying process. If it doesn't work, they you may have a faulty burner.Google is your Friend -
Made in Japan Maxells are considered excellent discs. Made in Taiwan Maxells are considered to be not quite as good as the Japan discs, but still ok. I have burned both with the 1693. Zero problems.
This sounds like a bad batch of media.
Did your 1693 come with Nero? If yes, try running the disc quality test after burning.
Liteon dvd recorder
By mangbok in forum DVD & Blu-ray RecordersReplies: 3Last Post: 21st Jul 2010, 14:37 -
Liteon SOHW-812SX power issue?
By pinetop in forum DVD & Blu-ray WritersReplies: 1Last Post: 20th Feb 2010, 21:48 -
Help Liteon DVD recoder
By killingme in forum DVD & Blu-ray RecordersReplies: 9Last Post: 24th Apr 2009, 18:46 -
LiteON 5005 weirdness
By kenmo in forum DVD & Blu-ray RecordersReplies: 53Last Post: 2nd Jun 2008, 12:05 -
LITEON LH20A1P186 Questions
By Nubile in forum DVD & Blu-ray WritersReplies: 2Last Post: 6th May 2007, 03:27
