Results 1 to 13 of 13
    Jan 2006
    To speed up the process of writing dvd's, would it be smart for me to get another DVD drive and install it in my computer (I currently only have one). I am sure that it would speed up the process, as I could both compress and write at the same time. I just don't know if there are disadvantages to this or not.
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Just make sure they are are both on a different channel if you're having two burners.
    Jan 2006
    cool
    thanks
  4. Member b1tchm4gn3t's Avatar
    Nov 2003
    Illinois, USA
    Originally Posted by Treebeard
    wow..talk about overkill
    If at first you don't succeed; call it version 1.0
  5. Member Treebeard's Avatar
    Aug 2002
    we have 3 of these where I work, 2 w/ dvd burners 1 w/ cd burners
  6. Banned
    Feb 2005
    USA
    @uttcut
    From what you wrote I would guess you want to have one drive reading info while the other is writing(burning). While this will decrease the time it takes to make your copies it also increases the chance to be making coasters. It's usually better to read the info to a hard drive and then burn this info out to your media. CD media has become more reliable for read/burning at the same time but for DVD media it's still a good idea to do one task at a time.
    if you decide to do reading/burning at once following waheed's advice is definitely a good idea.
  7. Banned
    Feb 2005
    USA
    we have a primera CD duping machine at work that holds 100 blanks. It burns two discs at a time for up to a 50 cyclic burn and will also direct print labels. It's price was less than 1/10 the price of the cheapest machine in the link above. In a little over an hour you can have 100 discs with labels. A good deal for promotion material.
  8. Member Treebeard's Avatar
    Aug 2002
    what I posted is different than just a duping machine.
  9. Banned
    Feb 2005
    USA
    What is it then? A coffee maker?
    It records discs, prints labels, and stack them for easy retrieval. Sounds like a duping machine to me. Does it do something else?
    According to the page you linked, "The Rimage Protégé II is a fully automated, networked, single-drive disc duplication and publishing solution."
    Jan 2006
    Originally Posted by ROF
    @uttcut
    appreciate it!
  11. Member Treebeard's Avatar
    Aug 2002
    It comes with software and a dedicated machine that can take multiple different jobs(images) over the network combined with control files that control what is labeled on disc. its not just a duplicator that takes a cd and makes 100 copies of it.
    more if you want to know
    http://www.rimage.com/products_detail_objectname_pr_Protege_II.html
  12. Banned
    Feb 2005
    USA
    Our Bravo pro does all that. Most duplicators I've seen including ours is hooked up to dedicated machines and I don't believe they sell any non-networkable duplicators anymore.
