What is the best way to burn DVD contents (Audio TS and Video TS) to DVD -R Disc. I mean Nero, Clone DVD , DVD Shrink or something. For example when I create my own DVD disc with my favorite DVD authoring program, then I should burn the DVD contents do DVD disc. This option is not suported for example in DVD Lab Pro. Using Nero, should I select "DVD Rom ISO" from left panel side of the program or should I select "DVD Video".Is it neccessery
to put both (Audio TS and Video TS) to Nero or only Video TS, because Audio TS contents is always empty. Maybe there is something more that I should check in Nero for quality DVD burning.
Regards.
QUALITY HAS A NAME
use Dvd video and drag and drop the main folder to burn. You should see the status bar at the bottom jump to the size of your video_ts folder. As far as burning software goes, the choice is yours. Everyone has their own preference.
ImgTool Classic. It will convert to iso for you and auto-launch DVD Decrypter (or ImgBurn) to burn the iso. It's free and fast.
Darryl -
I (a millions of others) use Nero. Just select Burn DVD-Video. Youll find Nero has already made the Video_ts and Audio_ts folder for you and will check that all the correct files are there before you burn and warn you if they are not.
DVD Lab Pro will burn your dvd. But I prefer Nero.
Still Stormin Norman.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
