  1. Hello,
    I downloaded the Limewire software only to
    find that i can't "download" the songs. i can request
    them (meaning i'm hooked up to the network), i just
    can't pull them onto my hard drive.
    as you may or may not know, its impossible to get help
    from the gnutella people. i looked under their FAQs
    and figured maybe my firewall is too high. so i
    followed their instructions about allowing gnutella
    in, but it still doesn't work. Any ideas? Thanks in advance for your
    help!
    Melissa
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'll assume you're downloading public domain music.
    When you add the file you want to the download list, what happens ?
    If in doubt, Google it.
  3. Banned
    Feb 2005
    USA
    This sounds like an active firewall issue but without further info about your firewall and any hardware I can't make a final determination. Like Jimmy said, when you click to download a file from the search screen does the file appear in the download section at the bottom of this same window? What is it's status (ie. connecting, waiting for hosts, downloading, etc.)?
  4. Member isogonic's Avatar
    Jan 2003
    @localhost
    yes back to the subject:
    you have a firewall and or router?
    Nov 2002
    Slightly off topic -- I generally use Shareaza, which connects to Gnutella, Gnutella2, and eDonkey networks simultaneously (it also acts as BitTorrent client, but that's another topci). Shareaza has a nice "network" page where it SHOWS you the traffic it's sending to each network, and which sections it's downloading. Great for troubleshooting.
  6. Firewall as far as I know. I'm going to check the other stuff you suggested tonight and I'll let you know. Thank you again for your tremendous help. This forum is such a resource for newbies like me
    Gratefully,
    Melissa
    Mar 2006
    Downloaded songs or other on Limewire automatically go to your shared folder which is part of the Limewire set-up when you installed it. It will not be on a seperate folder on your HD unless you created one.
    Knowledge is a good thing don`t abuse it
