When encoding a video_ts folder into an avi, the audio does not match the video. For example, when someone talks they're voice lags by about half a second. It's not much but it's noticeable and gets a little irritating. Anyone know how to fix that?
I can't help you. I am truly one of the dumbest people on this forum so no assistance from me. However, from what I see here, if you maybe give more info as to the type of avi file you want, the preset you use, something like that, maybe somebody will have info for you. I don't know. Just trying to help.
I get the same problem since upgrading to ffmpegX 0.0.9u. I've checked back some files converted with version 0.0.9t and earlier and they're fine.
I extract from a DVD using MpegStreamclip (which is in sync) and then encode to Divx using ffmpeg's mencoder option. As mentioned above, the sound and video are out by around half a second or so.
How to sync subtitiles to match Video/Audio
By VidHunter in forum MacReplies: 3Last Post: 17th Nov 2010, 15:55 -
Audio does not match with the video
By c018279 in forum Blu-ray RippingReplies: 1Last Post: 31st Mar 2009, 04:10 -
Video and Audio does not match
By hzgg2 in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 19:50 -
cant get audio to match video
By loa909 in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 06:35 -
Conversion of audio to match video
By deltaromeo in forum AudioReplies: 11Last Post: 29th Jan 2008, 12:01
