I've tried many programs and methods to Rip then compress and then burn to DVD. Most recently I've been using CloneDVD2 to Rip, Compress and then create an iso image. Then I burn it with Alcohol 120%. I get the best results using this method but I still get digital noise usually in the last chapters of the movie on about 1 out of 3 backups. Does anyone have any suggestions for this?
Thank you
Results 1 to 12 of 12
Digital noise as in macroblocking from too much compression?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
for future reference, you can't use tags in the thread title (unless you're Baldrick).
Any time you get ANY problems around the end of the disc, it means bad media. "Bad media" basically usually translates to uneven dye distribution around the outer edges, that's why it's always the last chapters that are affected . Use genuine Taiyo Yuden and you should not see this any more.
Another suggestion which works for me 100% of the time with excellent enough results to view on my DLP 52 HD tv is to simply run ANYDvd in the BG incase you are backing up any recent movie release. Rip and shrink with DVDShrink to ISO and burn that ISO with DVD Decrypter. It is by far the best combination I've come accross. Like I said - 100% great results every time.No DVD can withstand the power of DVDShrink along with AnyDVD! -
Sorry about the bold tags, it won't happen again.
I don't think the digital noise is from the compression because i've veiwed the movies from the compressed files all the way through and they don't have the DN. I assume it's in the burning stage. MY burner is a late 2003 Plextor PX-708A. When I use DVDShrink to compress and Nero to burn I get much more DN than when I use CloneDVD2 to compress and create an image and then burn with Alcohol120. The latter method gives much better results but I'm still getting the digital noise.
PS. the reason I used the /B tag is because I posted the question on a different forum and never even got one reply. I figure there are other people who have the same problem... -
Use better media. See www.nomorecoasters.com
I've been using Verbatim DVD+R media I have gotten better results with that than with the Sony DVDCoaster+R media.I thought the Verbatims were one of the best.
Thank you for all of the replies -
What he said.Originally Posted by jtoolman2000"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Sacajaweeda,
You just reminded me of a different question I have. How can you you rip and create an iso image from a DVD with 7 to 9 gigs on it with DVD Decrypter ? The instructions for creating ISO files with DVD Decrypter I saw only allowed an ISO image to be created from a DVD with less than 4.7 GBs. Am I overlooking something? -
Abond,
How can I take a DVD9 rip it with DVD Decrypter, create an ISO and have it compresed to fit on a DVD5? Is that possible or do I have to get a dual layer DVD burner to create the backup as a DVD9? -
If you want the backup as DVD9 you need DL DVD burner. If you want the backup as DVD5 you need to shrink the content with DVDShrink (for example). But this is nothing new.
I read your previous question as that it is not allowed to make an iso (not to burn an iso) with DVDDecrypter bigger than 4.7 GB. This is not true.
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 05:35 -
Removing/toning down digital noise/grain on HD video source.
By Killer3737 in forum Video ConversionReplies: 22Last Post: 27th Jul 2011, 18:37 -
Digital noise reduction - a warning
By Quasipal in forum RestorationReplies: 4Last Post: 7th Nov 2010, 14:16 -
How do you get rid of hissing air noise from digital camera video
By johnharlin in forum AudioReplies: 1Last Post: 23rd Sep 2010, 00:24 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57
