  1. Hi friends,
    I have two (2) DivX video files of the same movie which was ripped from a DVD. I have seen the movie in 700 MB DivX format. So, is there any way to convert or combine these 2 files to 1 and make it 700 MB size movie ? Also, I have a different movie which was also ripped but it is a single 1.4 GB file, unlike I stated above having 2, so is there any way for that also to resize the file size to 700 MB size without any loss of video and audio quality ? Thanks in advance.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    There are guides in the HOW TO section on how to combine the files. Most often, you will get audio sync issues.
    You cannot make a 1.4g file 700mb without losing quality. You can make it smaller, but you will be sacrificing a lot of quality to do so. With the current cost of cdr's (even dvdr's), there really isnt any point in losing so much quality just to make a movie fit on 1 cd.
    Google is your Friend
    Apr 2003
    Maryland
    I really should add that with the drop in DVD/RW drives and media price there is really not much reason to even want to attempt this. Unless the person has specific requirement for a 700MB Divx file, it's really pointless when you consider the dismal quality the movie will have. Even if you say that it's for viewing on a lap top or other portable device, there is no comparison between a real DVD original or backup and a Divx / Xvid convertion. It makes no sense at all.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
