I just read an article "http://msn.pcworld.com/news/article/0,aid,124312,00.asp?GT1=7645" that states a cd that was made with a cd burner will last only 2 to 5 years. Is this correct? It is also recommended that archival data be put on magnetic tape. I could use some guidance on this subject as I have been putting 8mm, scanned photos, video, etc. on DVD for storage.
Thanks,
azbound
Check out.....
https://forum.videohelp.com/viewtopic.php?p=1442335#1442335
and
https://forum.videohelp.com/viewtopic.php?t=289714
and a few more if you search a little
- e404pnf -
This article seems to have generated alot of topics in these forums. I guess the author served his purpose and we've done ours by exposing the lies presented in that topic.
Magnetic tape media is subject to more mechanical breakdowns and failures then burnt media.
Just for testing purpose:
1) Turn your oven on 85 degrees.
2) Put an egg timer on 10 minutes.
3) Take a magnetic tape and a burnt CD(Label side down) and place them on a cookie sheet into the oven for 10 minutes.
Now try and read the info from both medias. Your results may vary but the CD will more than likely have no problem reading while the tape(if you can unstick it from the tray) will be nothing but garbled mess.
*Warning: this test may cause damage to your tape deck!
DVD-RW lifespan
By lj01 in forum MediaReplies: 41Last Post: 31st May 2021, 11:35 -
Typical lifespan for a stand-alone DVD recorder.
By usually_quiet in forum DVD & Blu-ray RecordersReplies: 114Last Post: 27th Nov 2008, 22:21 -
lifespan of laser
By avextraxjp in forum DVD & Blu-ray WritersReplies: 10Last Post: 6th May 2008, 12:41 -
Hard drive lifespan for retaining data when not in use
By bigshotceo in forum ComputerReplies: 8Last Post: 15th Oct 2007, 10:40 -
Would a separate DVD player increase lifespan of DVD burner?
By kozara in forum DVD & Blu-ray WritersReplies: 10Last Post: 11th Oct 2007, 14:40
