  1. will all the dvd players playback the dvd tracks with bitrate lower than 2000 kb/s?
  2. Member adam's Avatar
    Sep 2000
    If they don't then they are defective.
  3. ok, but isn't that kind of non-standard thing?
  4. Member adam's Avatar
    Sep 2000
    No. There is no minimum bitrate requirement for DVD. You can go as low as you want, though obviously some bits have to be applied.
  5. thz for help bro
