  1. Hi,
    can someone tell me an easy and fast way of cutting DV files. I transferred some DV files from my Digital8 camcorder and they exist now on my PC. The files are very big (almost 8GB). I want to split it in two to save it on a DVD (without compression).
    When I used VirtualDub and selected a portion of the file, it too a long time and created a file that was 27GB! It seems like it was re-encoding the image.
    Any suggestions? Where should I start looking? For simple AVI splitting (keep same encoding) should I try something else?
    thanks.
    lmcnlcy
  2. VirtualDub: Video -> Direct Stream Copy
    Then Save as AVI.
  3. Thanks! That worked.
