Okay i have a complicated situation here. I have a original DVD, that i want to rip to avi uncompressed, and edit it, change the music and then burn it to dvd-r again.
here comes the problem:
I use DVDX and DVD2AVI (tried them both) and save it into a raw uncompressed avi file. Then i usepremiere to edit, and when im done i save the file to MPEG2 generic. and burn it with encore. the DVD works fine on the computer, BUT when i play it on my dvd player the picture flicker the whole way through.
has anyone had the same problem? please help
Agree with gunslinger -- if restream doesn't cure, might try dgpulldown to set flags.
FWIW, apologies for an un-asked-for critique...
If you're using DGIndex (dvd2avi) already, why not go avisynth route into prem, or at least into avi? RE: raw avi, if you mean as in no codec, might look to HUFFYUV, picvideo etc. Going from YUV type colorspace to RGB (as in usual uncompressed) you lose significant picture quality.
Anyway, just a couple of thoughts...
dvddecrypter to vob files to avi problems with subtitle
By carlos28355 in forum Newbie / General discussionsReplies: 17Last Post: 19th May 2010, 05:33 -
what to use for downloading video fro,m a camcorder
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2010, 16:37 -
Content fro Video Streaming
By alexandros27 in forum Video Streaming DownloadingReplies: 2Last Post: 20th Oct 2009, 10:53 -
DVD (VOB) to AVI Problems Using DVDFab
By BiggerJim in forum DVD RippingReplies: 2Last Post: 27th Feb 2008, 09:45 -
Capure fro DVD direct or thru AVI
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jun 2007, 02:54
