Results 1 to 12 of 12
  1. Member Huxley's Avatar
    Adelaide Australia
    Hi all
    I connected my Pioneer DVR 720H to my mac mini, 10.4.4 via firewire. I pressed play and quicktime sees the native dv pal stream. My question is why at 384*288?
    Thanks.
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    384 x 288 is the equivlent of NTSC MEPG-1,
    which is 320 x 240. The video is being seen
    as low quality Mpeg-1 stream.
    GIF--googling is fundamental
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Dec 2003
    Eugene, Oregon
    Originally Posted by Huxley
    Hi all
    Thanks.
    Your Pioneer recorder has various recording settings. It seems you are using one that allows long recording times to a DVD rather than an hour or two.
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    For many DVD recorders, 6hr. mode drops to MPeg1.
    http://www.kiva.org/about
    Jun 2001
    Silver Spring, MD USA
    And that resolution is out of spec for authoring the content to DVD. I'm surprised the Pioneer would do that, since it also writes DVDs (as well as to the hard drive).
  6. Member terryj's Avatar
    Perhaps they are looking at it from the fact of KISS, Ant.
    There's no way they can go in and put a menu that would
    enable you to pick ( based on a BitRate calc) a sweet spot
    to encode more than 4 hours of footage, let alone make
    it Simple enough for Aunt Edna to understand,
    and then author it to DVD.
    They have to make it dumbed down enough that the average guy
    taping theWorld Series or the Grandma taping her soaps
    weekly, could tape them all ( to HD) and then burn them to
    DVD without a lot of "fuzzy math" and "rocket science",
    in figuring out how to get them all on 1 DVD-R (DVD-5).
    And, pardon me if I'm wrong, but isn't this similar to what
    ZeroSix I believe use to say to do in the early days, the
    half-dv thing, cutting the resolution size 720 x480 down
    to 360 x 240 ( VCD standard size), but keeping the quality?
    [sorry if I'm showing my age a bit--or if I'm remembering the
    originator of this technique wrongly...]
    Urban Mac User
  7. Member ipdave's Avatar
    Sep 2003
    Noord Amerika
    PAL
    Video:
    Up to 9.8 Mbps* (9800 kbps*) MPEG2 video
    Up to 1.856 Mbps (1856 kbps) MPEG1 video
    720 x 576 pixels MPEG2 (Called Full-D1)
    704 x 576 pixels MPEG2
    352 x 576 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
    352 x 288 pixels MPEG2
    352 x 288 pixels MPEG1 (Same as the VCD Standard)
    25 fps*
    16:9 Anamorphic (only supported by 720x576)
    Audio:
    48000 Hz
    32 - 1536 kbps
    Up to 8 audio tracks containing Dolby Digital, DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have MPEG-1, DD or PCM Audio.
    Extras:
    Motion menus, still pictures, up to 32 selectable subtitles, seamless branching for multiple storylines, 9 camera angles. And also additional DVD-ROM / data files that only can be read by computer DVD drives.
    Total:
    Total bitrate including video, audio and subs can be max 10.08 Mbps (10080 kbps)
    * Mbps = million bits per second
    * kbps = thousand bits per second
    * fps = frames per second
    For more technical DVD-Video details read the DVDDemystified DVD FAQ section 3.4 or the mpeg.org DVD Technical Notes.
    NTSC (NTSC Film)
    Video:
    720 x 480 pixels MPEG2 (Called Full-D1)
    704 x 480 pixels MPEG2
    352 x 480 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
    352 x 240 pixels MPEG2
    352 x 240 pixels MPEG1 (Same as the VCD Standard)
    29,97 fps*
    23,976 fps with 3:2 pulldown = 29,97 playback fps (NTSC Film, this is only supported by MPEG2 video)
    16:9 Anamorphic (only supported by 720x480)
    Audio:
    48000 Hz
    32 - 1536 kbps
    Up to 8 audio tracks containing DD (Dolby Digital/AC3), DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio.
    Extras:
    Total:
  8. Member Huxley's Avatar
    Adelaide Australia
    Thanks for all the fast help.
    So all is working well and the dv output res is ok.
    Just I was expecting full pal dv from Fine recordings -the top quality setting as it was exported via fw.
    Dec 2003
    Eugene, Oregon
    I'm sorry but I misread your original post. You should be getting full 720x576 PAL DV resolution from the Pioneer's Firewire link. In fact, it can't be anything else. What application did you use for the capture? I know it works with iMovie and Vidi with my Pioneer 510. I presume it works with QuickTime Pro but haven't tried it. I can't export directly to Toast, however.
    The only thing that makes sense is that Quicktime did not report the size correctly.
  10. Member Huxley's Avatar
    Adelaide Australia
    Quicktime.
    Imovie see the dvr but will not import. No camera error.
  11. Member Huxley's Avatar
    Adelaide Australia
    Vidi displays 16:9 dv and saves as 720*576 61 mbits/sec DV
    Qt displays 4:3 dv and saves as 384*288 31 mbits/sec DV
    Anyone want 2 short clips - under 4 mb?
    Dec 2003
    Eugene, Oregon
    iMovie 5.0.2 imports from my Pioneer 510. Version 5.0 did not.
    Quicktime Pro produces a 640x480 .mov (I'm NTSC)
    Vidi produces a 720x480 DV file
    I have another option for you. Click on this link http://developer.apple.com/sdk/ and download the Firewire SDK 20. After installing this, open its folder, open the enclosed applications folder and firewire folder and open VirtualDV. In VirtualDV click create New to set a location where the video will be written. Then press the red record button to start recording. This produced a 720x480 DV file for me.
