Well, I bought my Lite-On LVD-2001 player when it first came out and I loved it. Recently it's starting to give me problems with non commercial discs (i.e. Divx, Xvid, etc.). I'm thinking about replacing it. Can someone give me some suggestions? I'm basically looking for a DVD player that can play Divx/Xvid, 1080i, and is region free.
Thanks for the suggestion mikel, but from one review, I read that
"The only misgiving is the lack of a progressive scan output via its component video outputs, however, progressive scan is fully supported by the DVI output. "
That's a big problem, since my tv doesn't have a DVI inputAny other suggestions??
The Oppo is a great player.
Also, it does support progressive scan on the component outputs. It doesn't support upconverting on the component outputs.Google is your Friend -
So I can't see a dvd at 1080i using a component connection, correct? I would have to connect it using the DVI connection.
Dvd player suggestions
By sweetcheeks82 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th May 2010, 06:41 -
Tax Refund = New DVD Player... Suggestions please?
By ufcdave in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Jan 2010, 14:17 -
Suggestions for good, RELIABLE player with
By timmus in forum DVD & Blu-ray PlayersReplies: 5Last Post: 16th Nov 2008, 20:58 -
Need suggestions on streaming video player
By Stephanee in forum Software PlayingReplies: 1Last Post: 5th Nov 2008, 01:52 -
LiteOn LVD-2002 DivX/MPEG-4/DVD Player
By Roundabout in forum DVD & Blu-ray PlayersReplies: 448Last Post: 25th May 2008, 04:18
