In general, the reason to convert from RMVB to any other format is because RM format / codec can't be read, and some other codec can. Since you did not transcode, stuff is STILL in RM codec, thus you did not solve the problem. IMHO, of course. Whatever works for you, the more power to you.
Results 91 to 113 of 113
rm formats can be read if you have the right player and codec. the reason why many convert to avi format as far as i know is that its the most widely used and many players can play them unlike that of rm. when i converted it, it no longer is in RM format but in avi (XVID specifically).
I have a similar problem. I got an AVI file that can only play on my Dell or other PC except the ACER. There is only audio and no video (Black screen).Originally Posted by gastorgrab
I have an ACER desktop with Athon X2 and an ACER notebook with Intel Celeron. The same AVI file can not be play on both ACER computers, however it's playing fine on my Dell and an Emachine with Intel Celeron.
I played the avi file thru Window Media Player, Real Player , and Media Player Classic.
Any help would be greatly appreciate.. -
I have this exact problem (audio only and black screen) on my ACER notebook trying to play RMVB file using Avsynth interface. Since I can't play the file on media classic player I can'tOriginally Posted by Baldrick
convert the RMVB file. So I thought somehow it's related to only ACER computer that's missing some thing (codec?? or something) because I can convert RMVB to AVI on my DELL.
And my DELL have no problem playing the avi file.
I still have the same black screen problem on ACER now... And I don't think there is a solution to dvdragon's post anywhere...
Since I can convert the RMVB on my DELL, I didn't bother to proceed further. Now, I just got an ACER Desktop and the AVI file doesn't play (black screen) so I thought it's has similar symptom thus I posted here. Is there a way to delete post?
Thanks for your VERY QUICK response. -
I updated the graphic driver on my Acer's notebook and now I am able to play the avs file thru the media classic player. Both video and audio works fine.
Everytime I try to save the avi I get "Stats file not found!" and then "Cannot start video compression: The operation is not supported. (error code -1)".
I'm follwing the first post exactly. Can anyone help out? -
Pepsi... Your AVI encoder is set to 2-pass / 2nd pass. Set it to single-pass encoding.
I've tried your WinAVI method before for RMVB to XviD... Audio was 15+ secs out of sync.Originally Posted by ross_diadame
With this guide, and thank you to the creator to this method, I've been able to guarantee the framerate and audio are consistent to any rmvb video that plays on my computer, all the way from resizing, converting to multiple colorspaces all the way to filtering and getting rid of Real's bits and pieces into any other codec I want 8) -
Hello,
I have followed step by step your recomendations and when I load the .avs script into virtualdubmod I've got the following error message:
Avisynth open failure:
Scripterror
irectShowSource does not have a named argument"convertfps"
(C:\CITESDOR\eps01.avs, line 1)
The avs file script loooks like:
DirectShowSource("C:\CITESDOR\Episode01.rm", fps=29.97, convertfps=true)
I also tried with
DirectShowSource("C:\CITESDOR\Episode01.rmvb", fps=29.97, convertfps=true)
or even (thinking the path could be the reason)
DirectShowSource("C:\Episode01.rmvb", fps=29.97, convertfps=true)
Can anybody help me? I struggle trying to convert rmvb into avi for my kids...
Syreocna-
[/img]
Is it possible to change the FPS command line to 25fps for PAL users? Do I need to put in 25 or 25.0?
Thanks a lot, this guide has been so very useful. Kudos to you, my man. -
For this one RMVB I have, when I play the AVS script in Vdubmod or Media Player Classic, it has the gray frames. But when I play the RMVB itself, it doesn't have the grey frames. Is there a possible way to not have the gray frames?Originally Posted by kschang
The reason I want to convert RM to any other format (preferably xvid, avi) is because rm is a worthless garbage format that should be banned from the internet. I mean, I've downloaded many RM files that I want to post on YouTube but I can't split them. I have no idea why. I've used Boilsoft's AVI MPEG RM WMV splitter and it won't split them. It just stalls in the middle of splitting the second file. So I've been trying to convert to a different format... but your guide isn't that great. Why would I want to change the framerate to a constant one? I just want to leave the video at the same frame rate as the original rm. I have a couple of videos that are 15 fps. If I set it to 30 that's a complete waste of space. This is ridiculous. Does anyone know why I can't split soem RM video files? What other programs are there that'll do the job properly?
I managed to convert the RMVB file to DIVX except the original files dimension was 640 x 480 and the converted DIVX file is now 320 x 240. How do I keep the original dimensions.
Oh my where are my manners, I completely forgot to say goodbye! -
I have been trying to convert rm files to avi using the method in this guide but I keep getting an error message.
I have installed Real Alternative 1.6.0
AVISynth 257
VirtualDubMod 1.5.10.2
I have saved the following script
DirectShowSource("D:\file.rm", fps=25, convertfps=true)
I can play the rm file in Media Player Classic but when I try to load it using the script I get this error
DirectShowSource: Could not open as video or audio
Video returned: "DirectShowSource: Couldn't open file D;\File.rm :
An object or name was not found.
Audeo returned: "DirectShowSource: Couldn't open file D;\File.rm :
I can open a wmv file in the same directory with Media Player Classic if I change the filename in the script so it seems that it is only rm files that AVISynth cannot open for some reason.
I have uninstalled and reinstalled all of these programs and I have also installed FFDShow and run the wmv config.
Does anyone have any ideas? -
Try removing the "D:\" and just have the file name and file type in the quotes. Make sure the RM file is in the same folder as your AVS script.
I have a strange problem. I have a 25fps RMVB which I have used the above convertfps script on. I've also tried using another script with AssumeFPS to convert to 23.976fps. However, it keeps coming out of sync in my MPEG2 for some reason even though it plays fine when I play the script in MPC or Vdubmod.
I have set the correct options in TMPGEnc. If it was converted to 23.976, I set it to 23.976, 3:2 pulldown in TMPGEnc. I've also tried converting it to 29.976 as well as just leaving it at 25fps and it would still come out out of sync! I've also tried opening one of the above scripts in Vdubmod and while it plays fine, when I save as an AVI in DivX codec, it's out of sync again.
The only solutions were to use WinAVIConverter but I don't like that because it turns out blocky in high motion scenes. Anyone know of a way to make that program turn out higher quality MPEG2? -
Try not to change audio streem to Full Procesing but Direct, its worked to me.
I am getting an error message:
avi import filter error: (unknown) (80040154)
Any clues? -
Originally Posted by MarkOD
After I have installed Gabest RealMedia Splitter v1.0.1.0 this problem was solved. (Install RealAlternative first).
I realize this is a very old thread - but recently I got a movie length RMVB file that I wanted to convert to a more common video format/container, and I found that it seemed to involve several steps, and/or more than one program.
Until I realized I actually already had installed a program which would do it in a single step.
Quick Media Converter
It took me a few trial before I got it so that QMC would produce an AVI of good enough quality -
I was a bit surprised that it took quite a high bit rate and a resultant file that was about twice the size of the original RMVB file to do it - but QMC was flexible enough to do this. I chose to use DivX format
(I am not experienced enough to know if this was the optimum format to use) -
but some of the other conversions to mp4 and avi seemed to give variable Frame-Rate and/or bitrate - which I did not want
Here were the simple steps:
Open/add the rmvb file in QMC:
The default setting on QMC is Easy Mode - if it is not already in Easy Mode click on the upper left Easy Mode button.
Then click on the DivX button and chose on the drop down menu -
in this example Expert Mode 4:3 -
this screenshot shows the settable parameters - since I was only doing a conversion I initially set the same frame size/dimensions, frame-rate, and bitrate - that converted just fine - except I saw some pixelation in some motion.
So I tried with a higher bitrate and that came out a bit better - but still had some pixelation - by trial and error I ended up using a bitrate that was almost 3 times that reported by MediaInfo on the original rmvb - which resulted in an avi file size double that of the original rmvb - but at least the pixelation was minimized.
Conversion to DVD - Mpeg did work very well also - but obviously the file size was much larger in the order of 2.5GB from a 700MB rmvb original.
Although both the YouTube and Q(uickTime) buttons can convert to MP4 they give the undesirable (for me) variable bitrate and/or frame-rate.
Perhaps setting the parameters in the respective Expert Modes such as Codec and/or FFormat may be able to do it? - but I haven't yet experimented to figure this out yet.
Convert rmvb to AVI
By pchan in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 05:09 -
How to convert AVI to .RMVB?
By whatever911 in forum Video ConversionReplies: 15Last Post: 29th Nov 2008, 11:29 -
What program will convert AVI to .RMVB quickly?
By Salva Veritate in forum Video ConversionReplies: 8Last Post: 13th Aug 2007, 22:15 -
A New Way To Convert RMVB to AVI
By RMVBMASTAPRO in forum Video ConversionReplies: 2Last Post: 27th May 2007, 18:41 -
THE BEST POSSIBLE WAY TO Convert RMVB TO AVI WITH VIRTUALLY NOTHING!!!
By RMVBMASTAPRO in forum Video ConversionReplies: 3Last Post: 26th May 2007, 03:07
