When I load the dvd in smartripper, it says no aspi-adapter available.... not sure what to do from here.. i havent used this prog in a while!
You can download an aspi driver, which is free. Or you can click "okay" on the error message and SmartRipper will continue to load and read the disk. The most common error I get from Smart Ripper is that the drive is locked. In that case, play the disk through PowerDVD or WinDVD and then resart SmartRipper.
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 19:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 21:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 15:26
