It difficult to tell is this has already been coverd, but I run 10.3.8 and QT 6.5 as I have the Pro for this QT and don't feel steve needs another $25 right now. I don't use 10.4.4 as one of my apps (alchemyDVR) has a much better interface pre 10.4.
is there a way to run Both qt 6.5 and 7.04 at the same time under 10.3.8? I ask as there is a WMP add on only for qt6.5.1 or above that Id like totry ( qt6.5.1 seems only to be for windows)
hoping there is a soluytios
cheers
rotuts
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
Both at the same time--NO.
Swappable--Yes (well, probably as YMMV)
Scott -
thanks
but would you explain 'swappable" a little more? and YMMV?
thanks
rotutsMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
Copy all files needed/used for QT6.5 (incl. components) to "/QTchoices/QT65" folder.
Upgrade to QT7, then
Copy all files needed/used for QT7 (incl. components) to "/QTchoices/QT7" folder.
Create a batch/script that swaps between them
Generalized e.g.:
Something like that...Code:Choose Key for QT6 or QT7 If QT6 then copy QT65/*.* to components & system folders and reboot Else if QT7 then copy QT7/*.* to components & system folders and reboot
edit: YMMV = Your milage may vary. (Too many system configurations of figure them all out)
First time ever a problem
By Randalliser in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 10th Oct 2010, 14:53 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 15:08 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
various time codes on miniDV. Want one time code.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 23:08 -
Can Not Do More Than 1 At A Time
By rfleisch in forum ffmpegX general discussionReplies: 2Last Post: 25th Oct 2007, 13:29
