Hi, I just updated my iTunes sofware and my video iPod software and now videos that I converted (from avi and vob files etc...) with ffmpegx will not transfer to my iPod anymore. They all worked perfectly before. Here's the catch, only videos that I change the info on (name, genre etc...) stop working - the old ones still play. I am at a loss as to what I should do. Is anyone else having this problem?
I restored my iPod with the old firmware but the same thing happens. I'm thinking that it's the new iTunes software just not allowing me to transfer them on.
Help would be much appreciated!
I really wish I hadn't updated my software now
note: vids that i converted with podner (another avi -> ipod converter) are still working. The problem seems to only be with videos i used ffmpegx to convert
Results 1 to 12 of 12
Yup.
I can say the same, after updating as well, ffmpegx encodes will not transfer anymore.
Anyone?
I updated iTunes and transferred an "iPod for TV" file successfully. Please send me test files zipped together a ffmpegX preset file of settings used to encode them, by using www.yousendit.com to major4@mac.com.
the problem seems to be with the new ipod firmware AND itunes 6
http://discussions.apple.com/thread.jspa?threadID=309676&tstart=0
Seems like everyone is having problems with it!
I used the new built in feature in itunes to convert a file - it transferred to the iPod just fine... then I went to info->options and changed the type to 'tv show' ... and now it won't transfer ... there must be huge bugs in both the ipod firmware and the itunes software. I'm hoping they come out with a fix asap!
Same here! Exactly the same, in fact.
However, i was having trouble with FFmpegX before the iTunes/QT update. Whenever i'd convert a file, it didn't matter what format, divx, MOV, mpeg, it kept giving me an mpeg-4 audio and video file, as well as a very large WAV. (3 seperate video files) This was especially bad with videos encoded with Sorenson Video 3.
If there's a way to fix this, let me know! I love the speed at which ffmpegx converts files, and i miss the ability to demux mpegs. (QT doesn't do that)
No.
As you said, right on to the iPod as it appeared in the iTunes window. I get the + marking to add, but it doesn't copy over. I've tried with various files that I've encoded with other programs - Podner, iSquint, FFMPEGX, etc…
Only ones that have been encoded using H.264 will copy over, none of the MPEG-4 encodes sized over 480X480 will go.
Still scratching my head over it all.
Heading over to Macworld, and see if I can shake some trees.
Thanks for the feedback.
480x480 is the max size (230,400 pixels) that the iPod will accept for MPEG4. You may go wider (or taller) but the total pixels must not exceed 230,400.
H264's max is 320x240 (76,800 pixels). Again, other ratios are okay as long as you respect the 76,800 limit.
See this thread:
https://forum.videohelp.com/viewtopic.php?t=290011
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
