Results 1 to 27 of 27
    Jan 2006
    Best being 1.)free 2.)quality & 3.) easy in that order.
    Sort of a (quickly catching on) newbie here attempting to get my Sony DV camcorder onto DVD. I have downloaded numerous freeware versions as I tread through forum after forum but have yet to get a DVD! Seems like winDV is the way to get it to my PC but after that nothing has worked. Have tried avi2dvd with QuEnc and that doesnt quite work either. Any suggestions would be great! thanks
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    I use QuEnc almost exclusively for conversion to DVD compliant MPEG2, and I'm very happy with the results. What specific problems did you have?
    Buy My Books
    Jan 2006
    I used QuEnc along with avi2dvd and get this error:
    avisynth open failure
    avisource: couldnīt locate a decompressor for fourcc xvid
    d:\avi2dvd_temp\avisynth_script_file.avs,line 2
    which seemingly is a codec problem but after loading every codec I could find nothing help. Is there a better (free) way besides avi2dvd to use along with QUEnc or what is you entire process of going from DV to DVD?
    thanks
  4. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    I use avisynth in combination with VirtualDub for editing. The error indicates that it thinks the source is an xvid file instead of DV-AVI, but without seeing the script, (that I assume avi2dvd generated), I can't tell what exactly is causing the error.
    Edit: if you aren't editing you could try opening the avi directly with QuEnc.
    Buy My Books
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    it sounds that your source is xvid and not any dvavi.....install the koepi xvid codec....or maybe something is wrong with avi2dvd,avisynth.
    edit: too slow.
    Jan 2006
    Sorry, my mistake. I mistakenly copied from a forum I was reading, the error is "for fourcc dvsd" not "for fourcc xvid". That may not make a difference, but my oops.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    install a dv codec like the panasonic dv codec or check our tools list undec codecs or dv.
    Jan 2006
    I have also tried the xvid codec with no luck, maybe I am not using it correctly, but executing the file is all I believe you should have to do. Maybe I'll try the avisynth, virtualdub route.
    Jan 2006
    tried seemingly every codec that was suggestion, panasonic included. thanks for all the suggestions though!
  10. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    You could try installing the Panasonic DV codec, but it would really help if I could see the actual script.
    Edit: I see we're all typeing at the same time.
    Buy My Books
  11. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Have you tried opening the file directly in QuEnc?
    Buy My Books
  12. Mod Neophyte redwudz's Avatar
    USA
    I've used the freeware version of DivxToDVD for quick and easy DV to DVD conversions.
    For quality, I do it this way; WinDV>Virtualdub Mod to edit>Frameserve to TMPGEnc Encoder>TMPGEnc DVD Author for menus and burning.
    Jan 2006
    Same error when I open up directly with QUEnc, except it says "line 1" instead of "line 2". What script file would it help to see? The one through avi2dvd?
  14. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Either one will do. I just want to see if it's using aviSource, directshowsource, etc.
    Just a thought, is the avi file a Type1 or Type2 DV-AVI?
    Buy My Books
    Jan 2006
    is TMPGEnc & TMPGEnc DVD Author freeware? i didnt think it was but follwing your quick link it seems it may be. Or is that just a trial with the dreaded "watermark"?
    Jan 2006
    log:
    [2:53:26 PM] AVI2DVD Started !
    [2:53:27 PM] Type mode : Avi Input
    [2:53:27 PM] Output : Dvd
    [2:53:27 PM] Encoder Selected : QuEnc
    [2:53:27 PM] Start demuxing the AudioStream No.1 ...
    [2:53:31 PM] Demuxing of the selected audio finished
    successfully ! [C:\Documents and Settings\DMirabile\My
    Documents\My
    Videos\movie\Avi2dvd_temp\Extracted_Audio.wav
    3907950 Bytes]
    [2:53:31 PM] Audio extracted renamed successfully !
    [C:\Documents and Settings\DMirabile\My Documents\My
    Videos\movie\Avi2dvd_temp\Fixed_Audio01.wav 3907950
    Bytes]
    [2:53:31 PM] Starts Wav->Ac3 convertion ...
    [2:53:34 PM] Audio converted in Ac3 successfully !
    Videos\movie\Avi2dvd_temp\AudioStream 1 WAV
    2CH.ac3 1465344 Bytes]
    [2:53:34 PM] Start creating avisynth script ...
    [2:53:34 PM] Avisynth script created successfully !
    Videos\movie\Avi2dvd_temp\Avisynth_Script_File.avs 212
    Bytes]
    [2:53:35 PM] Bitrate used : 7616 Kbpps
    [2:53:35 PM] Start video encoding ...
    [2:57:35 PM] Video encoded successfully ! [C:\Documents
    Videos\movie\Avi2dvd_temp\Encoded_Video.m2v 0
    Bytes]
    [2:57:35 PM] Job NOT Done. There are warnings ... Find at
    the log file the 0 byte generated file to focus where exactly
    the problem appears
    Script:
    # Avisynth Script Made By Avi2Dvd
    AviSource("C:\Documents and Settings\DMirabile\My Documents\My Videos\movie\092405to110305.avi", false)
    ConvertToYV12()
    LanczosResize(720,428,0.0,0.6)
    AddBorders(0,26,0,26)
    Jan 2006
    not sure if type-1 or type-2, tried using Gspot thinking that would tell me and it didnt, I dont think. Again, still sort of a newbie sorry.
  18. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Try changing the Avisource to DirectShowSource
    Buy My Books
    Jan 2006
    lost me....avisource to directshowsource in what QUEnc?
    Jan 2006
    Or in the avi2dvd?
  21. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    In the script. I don't think you can do it through avi2dvd so you'll have to edit the script directly. There should be a file with the extension .avs that when opened in Notepad should match what is under the Script heading in the log you posted above. Then you open the .avs script with QuEnc. (after changing AviSource to DirectShowSource)
    Buy My Books
  22. Member
    Jan 2006
    Get a script error.
  23. Member
    Jan 2006
    Back to my initial post, is there just a "decompressor" I need or is it not this simple? Or wait did I just realize what codec actually is? is codec the decompressor? Again, newbie.
  24. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Do you get the same error or a different one?
    Buy My Books
  25. Member
    Jan 2006
    "Script Error: Invalid arguments to function "DirectShowSource"
    gotta run, will probably pick up where i left off tomorrow, appreciate the help!!!!!!!!!!!!!!
  26. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    DirectShowSource uses slightly different parameters. Try modifying the line to this:
    DirectShowSource("C:\Documents and Settings\DMirabile\My Documents\My Videos\movie\092405to110305.avi", fps = 29.97, audio = false)
    Buy My Books
  27. Member
    Jan 2006
    That actually worked running through QUEnc and creted an MPEG. Which leads me to my next question, Would I then just run avi2dvd with QUEnc get my error, change the script file, then re-run it in QUENC? Or would there be a more permanent solution so it runs with that change automatically? Because this doesnt fix it to where I get an .iso image (my ultimate goal) through avi2dvd.
    UPDATE!!!!!!!!!!
    I was sent an updated (?)/different (?)/ new (?) Panasonic DV codec which maybe is specifically for dvsd. Im not sure if that codec varies between between xvid, dixv, dvsd, etc., or not (Im still kind of new), but it worked. The link is:
    http://movavi.com/codec/dvsd.html
    Again not sure if this is different from the codec i got before but this one worked. Thanks for all the replies to questions and for putting up with my lack of knowledge!!!!!
