Results 1 to 10 of 10
    Apr 2004
    Sorry if it's the wrong section
    What are the best solutions as theres so many:
    XVID to DVD
    VCD to DVD
    SVCD to DVD
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    The reason there are so many solutions is because there is no agreement on which is the "best". The best solution is the one that works for YOU and gives YOU the results YOU want. Try some of the tools listed, following some of the guides available, and see which solution YOU think is the "best".
    Buy My Books
    Apr 2003
    Largo, FL
    XVID to DVD
    VCD to DVD
    SVCD to DVD
    What's the problem being solved? Are those 3 different problems and you're looking for 3 solutions? Or are you asking which of those 3 solutions fits whatever problem you're having?
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    3 distincly different methods for these three alternatives:
    XVID -> DVD: divx2dvd (for a oneclick solution) or many other more elaborate processes. (See convert left)
    VCD -> DVD: Just author with TDA or DVD-Lab
    SVCD -> DVD: SVCD2DVDMPG or SVCD2DVD
    /Mats
    Apr 2004
    These one click solutions such as divx2dvd
    are they not plagued with problems such as sync problems and bed re-encodes?
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Well, there's always a trade off between ease of use and end quality - anything else would be a miracle!
    /Mats
    Apr 2004
    I'd prefer the end quality, what are best solutions for quality
  8. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Wouldn't "best" be a Rank flying spot scanner transfer connected to a top quality hardware MPeg2 encoder?
    All of those methods you describe are in the mud of quality.
    Better to say which is "better"
    http://www.kiva.org/about
  9. Member pchan's Avatar
    Mar 2003
    Singapore
    For Divx or Xvid to DVD, you can try TMPEnc if you do not need the encoding speed. As for VCD/SVCD, you can author straight to DVD with authoring software such as DVD-Lab. Since the VCD/SVCD video quality is not great, you will not get much quality improvement even with filter or the best MPEG encoder.
