Hello there, this is my first post, I've looked around and not found any info on this problem. I'm totally new to DVD burning.
I'm using AnyDVD with DVDShrink. Single layer discs burn and navigate perfectly but if I make a copy to a double layer disc I can't access items on the second layer from the menu. It causes my player to just drop out to it's screensaver page.
If I'm watching material that runs into the second layer it can make that transition, but can't jump there directly from the menu.
I'm suspecting software or maybe a setting somewhere but these discs are expensive so I'd like to find out what it is.
Any help would be greatly appreciated.
Russ
I see the same problem.
However I believe that the problem is in the palyer not the disk.
I make dl dvds with a second page memu items. They play fine in two of my players but not in my Samsung DVD-L75.
Try upgrading the firmware in the DVD player. -
Thanks for the reply. I was suspecting the player except I get the same behaviour on 4 different players, one being the burner it was made on.
Russ -
what about pressed discs as opposed to burned discs? if you use the menu to select a track on the second layer do you get the same results as you describe above?
I'm sorry, I'm so new I don't know the difference between pressed and burned, maybe mine are pressed not burned. Could you please enlighten me?
Russ -
the general consensus on this forum is to make the most compatible DL burns you should use RecordNow Max 7.3 and have a chapter point somewhere shortly after the halfway point of the disc. I've done this with a movie only, however, and not a menu disc.
Verbatim DL media seems to be well recommended as well. -
O.K. thanks, yes purchased dvd's work fine. Now the problem could be that these are the first time I've tried DVD+R as that's all I could find dual layer in. However, as I mentioned this problem exists on 4 different players including the burner it was made on so I highly believe it is a problem on the disc.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Burning to dual Layer discs
By Mastablastacious in forum DVD RippingReplies: 19Last Post: 5th Feb 2008, 18:50 -
Having trouble with dual layer discs
By red69 in forum Authoring (DVD)Replies: 6Last Post: 8th Sep 2007, 04:16 -
Getting I/O Errors While Burning Dual Layer Discs
By VanCity in forum Newbie / General discussionsReplies: 5Last Post: 31st May 2007, 23:35
