Hey,
Am burning a DVD using NERO...How and where can i find out the region code that is set.... I belong to the PAL region but want to burn my DVDs in NTSC format with region code 0.Please help.What is the default value? Any clues would be of help....
cheers,
Mad
what is your video source? a dvd that you have ripped? or something that you convert like avi to dvd?
In general, anything burned by Nero itself would NOT have a region code at all, but then, we'd need to know a bit more about your video source, as Baldrick had stated.
In other words....simply changing the region code will not change the disc from PAL to NTSC or vise versa.
The disc will still not be easily playable in America if it is PAL...no matter what region you set for it. -
hey,
This is my showreel(animation) that i want to burn...i have created the vob file using ulead movie factory...I saved the AUDIO_TS & VIDEO_TS folders onto the hard disk when i created the output so that i can burn it whenever required...I find it easy to use Nero than burning it straight from Ulead...Hope this was the information that u wanted...
Sorry for posting the thread in the wrong forum....Was unable to identify where to exactly post it.. -
If the settings in Ulead were PAL then it is already PAL material that you will be burning...same thing if the settings in Ulead were set at NTSC.
Wrt NTSC i don't have a problem...I've set the video settings to NTSC only....So am sure abt the format although i would like to check the properties after burning, just to be doubly sure...It is only abt the Region Code...Just want to ensure that it plays properly....
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Region Code Samsung ht-bd1220 - Code does not work
By mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 15:44 -
Help ! Panasonic BD-60 UNLOCK DVD region code (Region 1)
By aexp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Sep 2009, 11:24 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 13:42 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34
