MPG to DixX or Xvid via VirtualDub
My neighbor gave me 2 tvshows in MPG format. I use Virtualdub to convert to DivX. Also, I tried Xvid too. I getting an audio out of sync. It start fine and get worst near the end.
I this follow the following guide to the tee.
https://www.videohelp.com/avi2divx.htm
The original topic was MPG to DixX or Xvid via VirtualDub. I decided to change it because it becoming a very infomative discussion on how conversion can lead to out of sync more specifically in the audio.
There has been several similar topics. I just hope everyone can learn something from this thread.
[/b]
Results 1 to 13 of 13
Use MPEG Tools in TMPGEnc to demux the audio from the video. Check its format, make sure it's NOT VBR. If it is, you need to reencode it with a tool like BeSweet/BeSweetGUI to CBR format.
After that, you can disable the existing audio stream in VDUB under Streams, then add in your re-encoded audio, and do a stream copy / interleave and that SHOULD solve your sync problem. -
Then I dare say it's something not 100% OK with your source...
/Mats -
or try "fix" the source with videoredo. then convert.
or save the audio as wav with goldwave and use in virtualdub. -
All I see is Save as AVI.. from the File menu.
[EDIT]
Ah, nevermind, I didn't see the link to the tutorial. -
Originally Posted by mats.hogberg
Originally Posted by vodreaux
/Mats -
Thank You for all the information. I hoping to find a 1 click solution to convert files over to DivX or XviD.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
How to get Xvid encoding in VirtualDub
By Dr_Asik in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2010, 10:31 -
Virtualdub can not open xvid
By quxote in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2009, 00:11 -
win98 xvid and virtualdub?
By dridge in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 22:34 -
Converting DV (on PC) to xvid through VirtualDub
By Wills in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 11th Jun 2007, 17:10
