Hi, im using a Pannosonic PV-GS19. I wanted to know if my Microphone was decent enough to film outdoors for a independant film. Or if there was a microphone for DV cameras
some one please help me
Different Mics for different problems. Describe what you are trying to do in this "independent film".
http://www.google.com/search?client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial_s&hl=...=Google+Search
Serious folk generally use a separate sound guy with a boom holding the mic in close just out of video frame. Connection can be wire or wireless.
http://www.kiva.org/about -
AFAIK Panasonic GS19 doesn't have a microphone input, so I guess you're stuck with the built-in microphone.
One of the many reasons I just replaced my GS19 with a GS250....Originally Posted by Gobs
Later,
Bob T. -
Another option is to get a good mic (wireless lav or boom as in picture in previous post) and record to another source, like a minidisc recorder. You then have to make sure you slate the beginning and end of each shot ("like they do in the movies") so you are able to sync the two soundtracks. Then replace the camera's sound with the track recoded on the external recorder when you edit.
If you're serious about making a film, the onboard mic your GS-19 is not going to give you adequate sound unless you're within a few feet of your subject. Any more than that and you get too much reflected sound.
Check out www.dv.com -- they have lots of info on cameras, audio, etc. The guy who hosts their audio forum has a number of books out (and free articles you can access thru the site) that go into great depth on creating good audio for digital video. His name is Jay Rose, and his stuff is absolutely excellent. I got a copy of "Producing Great Sound for Digital Video" and it is the probably the most useful book I have ever read in my life. -
Oops -- I meant to say I got "Audio Post Production for Digital Video", not Producing Great Sound...
I bought a Rode Video Mic a few months ago and it's fabulous. It's got a 3.5mm plug, hot shoe mount, wind cut function, and it can be used as either a desktop mike or mounted on a boom pole. Google it. It's great (and cheap).
what microphone do i need?
By dakota5369 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Apr 2012, 02:03 -
Need microphone for Kodak play touch video camera
By 1drwahn in forum AudioReplies: 3Last Post: 17th Jan 2012, 12:18 -
Looking for a Microphone...
By duderdude2 in forum AudioReplies: 6Last Post: 2nd Feb 2010, 16:35 -
How to pick an on-camera wireless microphone ?
By AAC in forum AudioReplies: 0Last Post: 21st Jul 2008, 14:30 -
Which microphone?
By etibo in forum AudioReplies: 1Last Post: 5th May 2007, 14:10
