Results 1 to 27 of 27
    Oct 2005
    Michigan
    hi, are there any freeware programs out there that will convert real media (video) files to avi or mpeg? I'm looking for something simple (that doesn't require extracting audio or anything like that). I had ultra RM converter but that doesn't work for larger rm files.
    thanks
    Nov 2002
    Real Alternative, then feed it to VDub...
    Jul 2005
    ca, usa
    hi kschang
    can you more specify how to do that real alternative then feed it to vdub
    gmmm
    Apr 2004
    Miskatonic U
    Do a search - there was a long thread on the last week.
    Read my blog here.
    Oct 2005
    Michigan
    thanks but it's just too complicated.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    what ? Searching, or the process ?
    Read my blog here.
    Oct 2005
    Michigan
    the process
    Nov 2002
    Really, I can do the whole thing in about 2 minutes (setting it up, I mean, not the actual transfer/reencode).
    I wonder which part you actually read? Maybe I need to write a new guide making small improvements on Baldrick's version, feeding straight to QuEnc or TMPGEnc...
    Nov 2002
    Just re-read Baldrick's guide, it's perfect as is, except maybe you need to read the LAST message as well.
    Then pick one of the "covert to VCD using VirtualDub" guides and you should be able to figure out what to do next.
    Or do you really need a specific guide to hold your hand every step of the way?
    Oct 2005
    Michigan
    i actually didn't find Baldrick's guide, where is it? found a different one by gastorgrab or something...
    Oct 2005
    Michigan
    i tried it but it didn't work. when i tried to open it with windows media, says something like video (file name) was not found.
    Nov 2002
    Sorry, "something like" doesn't help us diagnose your problem one bit.
    And WHERE in the guide I linked to even MENTIONED "Windows Media (player?)" ? Are we even talking about the same problem?
    Oct 2005
    Michigan
    DirectShowSource: could not open as video or audio
    video returned: "DirectShowSource:could not open file c:\Desktop\rm\3227_04.rm an object or name was not found
    audio returned: "DirectShowSource:could not open file c:\Desktop\rm\3227_04.rm an object or name was not found
    (C:\Documents and Settings\Jim\Desktop\rm\video.avs, line 1)
    according to Baldrik's guide...
    "Open the video.avs with Windows Media Player and it should play.
    You can now import the video.avs file in for example Virtualdub, Tmpgenc, Windows Media Encoder or most other editors. When you import the file in your tool select All files under Files of type to see the .avs file. "
    Nov 2002
    Good, we're now talking about the same problem.
    Is Real Alternative installed? Did you try opening the RM file in WMP?
    Oct 2005
    Michigan
    yes i have it installed. i don't have real media installed though, cause when i installed real alternative it told me i should uninstall it. i tried opening the rm file with wmp and it said that it couldn't open it. one or more codecs may needed to play the file.
    Nov 2002
    When you install Real Alternative, it told you to uninstall itself? That makes no sense at all...
    Dec 2004
    Australia
    No, sounds like if you have Real Player installed and you install Real Alt, it tells you to uninstall Real Player.
    Makes sense since they con conflict. But then if you already have Real Player installed, why bother with Real Alt? Just install Gabest's dshow real filter.
  18. Member
    Oct 2005
    Michigan
    when I installed real alternative it said that i should not have real player installed as well. then it said do you want to uninstall it (real player) i said yes and now it's uninstalled.
    Nov 2002
    But you STILL cannot watch RM file inside WMP?
    Oct 2005
    Michigan
    right. perhaps it's something i'm doing wrong in the set up of it??
    Nov 2002
    Do what Celtic_Druid said: get Gabest's Real DShow Filter, and see if you can now play RM in WMP.
  22. Member
    Oct 2005
    Michigan
    where is it? i searched for it in the tool section and couldn't find it. looked on the internet and only found splitters (is it the same thing??)
    thanks
  23. Member
    Oct 2005
    Michigan
    thanks
    hey guys, i appreciate all the help you've been giving me but a found a simple program that worked much easier. it's called super. it can convert any media file to any media file.
    thanks though!
  24. I'm a MEGA Super Moderator Baldrick's Avatar
    added "rm to" to the super 1 in our tools list...so you will find it if you use search for rm to.
  25. Member
    Oct 2005
    Michigan
    i would wait on that...at first it didn't work for me. i went to the forums for the super1 and read that the guy who made it didn't put the codecs for real player in the right folders, so you have to manually move it. So I wouldn't put a listing for it until he changes it in the next update like he said he would.
  26. Member
    Nov 2002
    Sorry for the confusion, but basically, yes, we mean the splitter (which is ALSO the video/audio decoder for Real Media in DirectShow).
