    Dec 2005
    Hong Kong
    Hi,
    what's the easiest way to convert DVD+R to DVD-R?
    Since DVD+R also have the VIDEO_TS directory, can I just copy the whole directory (with all VOB & IFOs) and burn it onto a DVD-R? Will that work?
    Thanks!
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi Teresa Lam,
    Welcome to the forums.
    If it's an unencrypted disc (which is likely, as it's DVD+R) then a straight copy to disc, or copy to PC then burn to disc should work.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    DVDDecrypter (free), ISO read to copy the +R to your hard disk, ISO write to put it on a -R.
