Hi
I have been given a portable mp4 player that requires files to be converted to 'mvs' format before it can play them.
Unfortunately, I do not have the software that came with the unit so I cannot convert my movie files to play on the player.
Does anyone know of a convertion program that can convert to 'mvs'?
I have searched the net without any success.
Many thanks for any help in advance
mesaboogieman
Results 1 to 11 of 11
Never heard of MVS. You know of any samples on the Internet? We can then take a look...
Sorry, not seen any to date. It seems to be a format the Chinese manufacturers are using.
mesaboogieman -
what is the name of the portable device?
you maybe can convert to mp4,3gp with some tool like 3gp converter and just rename to mvs. -
Heres a site about it....Good Luck
http://www.auhe30.dsl.pipex.com/home.htm -
Thanks canadateck, small problem, the link to the zip file does not work for me. Is it correct, and what is it anyway. If it's a converter does it definately do 'mvs' format?
Thanks for your input.
mesaboogieman -
I cant post the software here,Because the file is to Big.2mb limit.
I think the website link I gave you has it..(I think). -
Thanks for the info. Can you tell me what the name of the converter/file is I should look for.
mesaboogieman
Memory card video file in .MP4 format does not play
By wakawaka54 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2011, 03:54 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 12:41 -
Is it possible to burn MP4 video file in CD-R and run it on my DVD player?
By gregnovella in forum Newbie / General discussionsReplies: 4Last Post: 30th Jul 2009, 14:54 -
convert mvs-tsm.r movie format to iPod?
By kieran_92 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2007, 06:26 -
can i play mp4 format files on my dvd player
By vampelle in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2007, 06:36
